90CQ Turbo swap project
  • etsola
    • Feb 2015
    • 285
    Hi there, first and quick post - more to come.
    Quick question :
    I will eventally drop an AAN engine in it - I know the intake creates a problem and will need to be customized to fit the Coupe's small chassis (also the radiator is the way
    Will a 3B intake manifold fit (fit on the AAN)
    Will it have the same inlets on it (vacuum, etc...)
    Will it be easier for my setup ?
    Basically : 3B intake or AAN modified on the AAN head (engine) ?
    P.S. I'll have a lot like those to come. I'm slowly sourcing the parts and putting this together.
    P.S. #2 Anyone knowledgable on 7A engines in the Ottawa, Canada region ? My 1990 (1st gen) CQ doesn't run currently
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    90 cq,what typ of chassis? b2-b3-b4? or buildyear?
    TWINCHARGED power,zero lag
    AEM W/M injection
    • etsola
      • Feb 2015
      • 285
      Sorry - 1990 pre-March - B3
      • quattro-nick
        • Sep 2012
        • 1746
        • Country: Belgium
        3b or aby or adu intake will fit.vacuum lines need to be adapted,also isv lines,it's not a straight fit.
        i have modified my AAN intake in a b2 chassis with the radiator on the origional place
        AEM W/M injection
        • etsola
          • Feb 2015
          • 285
          What do you think is easier ? Modifying the AAN ingtake to fit or modifying (adjusting) the 3B (ABY or ADU) intake ?
          What about piping routing for the intercooler afterwards ? Easier with AAN or 3B intake ?
          Thanks for those wuick replies ! !
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            if you fit a reverse (3b-aby-adu) intake manifold you can place origional turbo hoses and intertcooler from a 3b in a b3 chassis ,it means that everything is a direct swap.
            with a modified AAN intake you need a custom intercooler and pipework
            i think it all depends what you want with the car and how handy you are in making things
            will you run with a standaard AAN engine or more horsepower?
            AEM W/M injection
            • etsola
              • Feb 2015
              • 285
              For now, stock AAN.
              It's just for me, sourcing AAN parts is a lot easier (were found in S4-S6's)
              3B's were only found in Audi 200 Turbo Quattro 1991 (1000 of them sold in the US).
              I can make-fabricate things - But that is mainly the question - Will I need to make less fabrication with a 3B intake (I guess piping is not so hard to come about) ? Or less with a modified AAN intake ?
              The question is also, I already have my AAN intake and all - but I could source a 3B intake on this forum for around a couple hundreds $$
              Also, using a 3b - no need to delete the ABS module and tilt the rad right ? Or this can also be avoided with the modified AAN ?
              Thanks again
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                you have also 3b in the first s2
                here some pictures of my car
                probably you need to make also a custom servopump bracket
                AEM W/M injection
                • etsola
                  • Feb 2015
                  • 285
                  Nice bay !! Was it difficult to fabricate/modify the intake ? My brother bas access to an aluminium welder.
                  I know the 1st S2's had the 3b's. That's why I'm inclined to think it'd ne easier to fit
                  • poor-boy
                    • Feb 2010
                    • 896
                    An ABY is easier and the radiator fits back in it's original place, try and source ABY bits for the AAN.
                    Life is a rollercoaster
                    • Wizard-of-OD
                      • 926
                      • Home: Syria Current: Canada
                      Could lend an ear and meet a fellow enthusiast from the region.
                      Issam N. Abed
                      iABED Industries
                      iABED Email | Facebook
                      The build thread
