ABY rear diff internals info please
  • poor-boy
    • Feb 2010
    • 896
    Gents and others.
    Would someone have info on the placement of internals on the rear diff?
    I have put my rear diff back together and have a shim left out but I don't know where it goes.
    Thanks in advance
    Life is a rollercoaster
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    Picture of this shim would help.
    • poor-boy
      • Feb 2010
      • 896
      There we go bud.
      • A1QSHIP
        • Aug 2004
        • 975
        It goes behind one of the crown wheel carrier bearings. The bearings on the side of the diff that the stub axles go thru. Most important as without shim in place there will be excessive gear clearance leading to noise leading to gear failure. If you can measure the thickness with a micrometer it may help to determine which side it came from. One of the side bearing shims is a fixed value that the setup measurements are based from
        HTH, Chris
        "Nulla tenaci invia est via"
        • poor-boy
          • Feb 2010
          • 896
          Iam trying to avoid taking the new big seal back out and ruining it so just trying to see which side it goes into.
          It is less than 1mm in thickness, 50mm outer and 45mm inner hole.
            I already told you where they go Taff
            Pull the flanges out, place washer on flange shoulder, refit flange. Tighten bolt, from memory there is a torque angle setting too
            • piotr
              • Jul 2012
              • 1470
              And yes,they are stretch bolts so I would use new one.
              • poor-boy
                • Feb 2010
                • 896
                The shim has now been fitted to the flange and new bolts used to attach flange to diff.
                Now the diff does not turn by hand
                Are there any pics or anything of exactly where the shim is supposed to go?
                • andy10v
                  • 5996
                  Vagcat picture any help?
                  Sold ABY-stock
                  • andy10v
                    • 5996
                    Only pictures I can find of when I had mine apart
                    Sold ABY-stock
                    • A1QSHIP
                      • Aug 2004
                      • 975
                      Were any of the bearing races removed from their places?
                      • poor-boy
                        • Feb 2010
                        • 896
                        Guys I appreciate everyones help once again on this great forum.
                        Iam a fool and left one shim out and put another in the wrong place (distracted by the dog trying to attack someone).
                        I have been kindly sent the information required and once again to all.
                        • poor-boy
                          • Feb 2010
                          • 896
                          All the insides were remove to be cleaned as had swarf in the gearbox, it all went back together (apart from one shim) and worked ok by hand untill I took the flanges out again.
                          • A1QSHIP
                            • Aug 2004
                            • 975
                            I will post up pictures from the repair manual when I can.
                              I don't think Taff pressed the races out of the casing/cover, so the pre-load shims wouldn't have been affected
