finished mounting coilpacs, only left to conect them..
Abt C5
lots off stuff left to do.. but i did some work this weak. next weak i will finish the intercooler,pipes, and hopfully get new injectors. so hopfully i can start the engine sooonAttached FilesABT C5 Lord Of The Rings
2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
kostic.nuComment
Originally posted by zlobocover to cover the turbo
is that carbon? if so, i hope youve used a lot of heat shielding on the underside of the carbon....some epoxies will melt from the temps a hot turbo/exhaust manifold can put out.
-bIm not the percent you think survives,
I need sanctuary in the pages of this book...Comment
yes that's carbon and there is heating shild under.. i am only going to use it when i am going to yearly thecnical check out so the car can be street legal. (looks like it's not tuned)ABT C5 Lord Of The Rings
kostic.nuComment
not so much left now, some injectors, andt some other stuff, and then i think i can fire it upp.Attached FilesABT C5 Lord Of The Rings
kostic.nuComment
yesterday i was thinking of firering upp the engine for the first time, I checked the spark it was good with the new coilpacs. i dident start the engine because i found that the fuel rail was leaking. so i have to make a new fuel rail or get a new one.ABT C5 Lord Of The Rings
kostic.nuComment
had to replace the coilpacks.... I need to use the 1,8ts coils cause they are runig as dwell... so the other coils i had befor made the spark come erlier and that made some big bangs..Attached FilesABT C5 Lord Of The Rings
kostic.nuComment
why does your valve cover have a patch welded on?
