Abt C5
  • terrybullwon
    • Mar 2006
    • 8782
    WOW Not worthy
    Chef
    • zlobo
      • 967
      Abt C5r +500
      Started making the new fuel system today, tear down the old fuel lines.
      ABT C5 Lord Of The Rings
      2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
      2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
      2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
      kostic.nu
      • olsonjus
        • Dec 2003
        • 293
        I hope you can form those pretty velocity stacks to fit this runner dimensions on the inside. This the inside is the dimension of the flange I'm sending your way next week.
        Regards,
        Justin
        • geryS2
          • May 2006
          • 814
          • Home: Belgium Current: Portugal
          #94
          Cool job man, I want those Dunlop Tyres too, do u know if their harder compound than Yokohama A032R ? (A032R are too soft compound for road use and much too noisy for highway !, scotching like glue but after 10 000 km: dead ! )
          Keep on the passion alive !
          S2 's and oldtimers
          • zlobo
            • 967
            Regards,
            Justin
            this is the first one he made he will make a tool for the oval once i hope. Or els i have to make em oval in the end . Thanks man
            kostic.nu
            • zlobo
              • 967
              tunlop makes them in both in soft and medium i think i havent tested them yet. thnks
              kostic.nu
              • zlobo
                • 967
                some more updates, the fuellines are nearly reddy, the holdes are finished.
                kostic.nu
                • zlobo
                  • 967
                  don some more work made a new exaust 3" all the way and a wrc metal cat,
                  every thing is made from stainles. And its looks much better than the japs mufler i had befor, i dont know why i ever mounted it....
                  tomorrow i will start to make the new catch tank,
                  kostic.nu
                  • Sweeper
                    • 1317
                    • Country: Latvia
                    #99
                    nice look lime min dahlback exhaust pipies
                    Vadim.
                    New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
                    • zlobo
                      • 967
                      thnks,
                      kostic.nu
                        It all looks very good now, how much ground clearance does the exhaust have under the rear axle compared to the front part of the system?
                        • zlobo
                          • 967
                          i got atleast 10cm under the pipe at the rear axlel and in front a bit more.
                          below u can se the old exhaust its ugly.
                          kostic.nu
                            that exhaust does look a bit daft. ive goto have the exhaust re engineered under my car because it knock near the driveshaft so might go that route. the front catches now and then on speed humps but thats it. I'll check what clearance I have on the front. Is your car on H&R's?
                            • zlobo
                              • 967
                              my car is on kw:s fully adjusteble. But i am going to adjust the exhaust a bit more i can ezely free 2cm more.i can take a pic in the evnigng and post it so you csn se how it looks in the front end.
                              begori had problems with the front end cahing at speed bumps but then my car was lowerd 60mm in front.
                              kostic.nu
                                the reason I have problems on mine is because they fitted the flange in a stupid position so will have a flexi pipe fitted and the rear done.
