What a beauty she will be Pirvu. Great job thus far. Question is this fitted with hydraulic rear suspension?
200 20v turbo avant resurection
The pas pump is the same with all the 44 chasis...the brake and..iff fitted... self leveling suspension is actuated by 150bar 2 pistons same as s2 and steering side is actuated bu 6 postons and 120 bar different as S2 which has vane type pump.Comment
About brakes... same as S2... 150 bar, brake bomb etc. Plus.. iff fitted.. the self leveling suspension is using same line like brakes but with another 2 bombs for each rear shock absorber and leveling valve plus an huge oil reservoir.
I will make a picture with both pumps....Last edited by Pirvu Eugen; 3 March 2017, 18:33.Comment
Regarding rims.... What you think will suit this car?
Should be 18 inch...to work with the 360mm disks and cayenne calipers..
Thank You!Comment
Rear suspension fitted. the diff is on with poly bushing too....hope will not be too loud.
Next...front suspension...I have all the parts needed.
Difficult with pictures....i will try to post some.
Ahh...btw... can somebody tell me which hose goes were at the rear diff lock?
I have one blue and one yellow.
I want to fit them ok from first. Thank You!Comment
this is coupe diff, but it should not be the sameRear suspension fitted. the diff is on with poly bushing too....hope will not be too loud.
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
steering wheel lock position
Hi! I was wondering if somebody knows iff the steering wheel locking position on these cars is in the straight position.
I have dismantled the rack for refurbish..but i didint noted the pinion position.
Thank You!Comment
Usually 5 minutes off straight... but guess someone with a 200 should really confirm...Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
It has a little slack...but wondering if is made to lock exactly in the middle of the rack..
Thank You!Comment
Front suspension and steering finished today.
New bushings, tie rods, steering arms, shocks.
The steering lock is with steering wheel centered.
I will start with the 6 speed gearbox install untill the rear hubs come back from the machine shop for changing the bearings.
Then, i will finish installation of the rear suspension too.Comment
