Bens Audi 80 track car project
  • terrybullwon
    • Mar 2006
    • 8782
    I have another car to finish off for some one else with lots of nice parts and toys on. Building it for Club/Pro Time attack spec.
    Out line of spec
    Engine
    GTX35R
    Custom pistions
    KKD manifold
    Antique wagner inlet ( first edition )
    Tial 50mm gate
    Tial BOV
    Adjustable pulleys
    Machined breathers
    Wiggings style fittings with aluminum pipe work
    Solid lifters
    Triple plate clutch
    Griddle plate
    1.8T coils
    Error 404 Raychem harness
    Custom engine harness
    Tatech pro ecu
    4" down pipe
    Rear mounted rad
    dual 044 pumps
    Walbro 450 lift in tank
    1000cc injectors
    Billet fuel rail
    Turbo smart FPR
    Suspension / Geo
    Audi motorsport dampers 2 way adjustable light weight aluminum casings
    Tubular front wish bones with rose joints
    Rear end powerflex bushed with rose joint linkages
    DMD hub to damper billet brackets
    Front strut towers corrected
    Lower king pin extended to correct wish bones
    DMD motorsport steering bracket with rose joints
    MR2 rear mounted PAS pump
    Brakes
    Front 8 piston RS6 DMD carriers
    Padgid RS14 pads
    Rear 4 piston porsche with extra hand brake calipers
    Exhaust
    4" down pipe
    4" oval along centre section
    4" round over shafts to rear box
    3x simonds silencers
    All V bands
    Saftey
    5 point harness's
    multi point cage with suspension tied in
    life line fire
    fire wall
    roll over valves
    Rear rad with Craig Davies water pump
    Fan Cowl and inlet housings from rear window
    Cleaned rack with DMD bracket
    Home made fuel manifold -8AN
    Chef
  • terrybullwon
    • Mar 2006
    • 8782
    Ajustable top mounts set back to 6 degrees of castor before
    Chef
    • terrybullwon
      • Mar 2006
      • 8782
      Rota wheels
      Error 404 harness
      4" down pipe and motor
      Chef
      • terrybullwon
        • Mar 2006
        • 8782
        Tail pipe
        Chef
        • zafra
          • Jun 2013
          • 320
          • Country: Spain
          It's scary....
          Step 1: setup. <==
          Step 2: potentiation.
          Step 3: enjoy.
          • terrybullwon
            • Mar 2006
            • 8782
            Hub carriers from DMD
            Chef
            • terrybullwon
              • Mar 2006
              • 8782
              4" down pipe friendly sub frame with solid gear box mounts
              4" down pipe
              More billet from DMD
              Steering arms for the dampers
              Chef
              • Teg
                • Sep 2011
                • 158
                Great work! Will love seeing a 5 pot audi Tie Attack car. Much more interesting than the usual collection of evos
                • simon20vq
                  • Dec 2010
                  • 1379
                  Excellent, perfect body the saloon and a great spec. Impressive work chef!
                    Loving your work Chef
                    Those steering arms and hub adapters are sweet.
                    I've been playing with some similar designs for steering arms to be able to correct some bump steer but keep road car rod ends. How much have you been able to dial out?
                    • Thuppu
                      • 4115
                      Nice project! From where are you going to take the air intake to the rad, and what size hose are you going to use? My friends PKKM typ85 is taking the air from the small rear side windows with 250mm hose. Can post up a pic if wanted.
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        i think from full droop to full bump we should see 0-2 or 0-3
                        Its hard to tell at the minute as the springs only turned up yesterday and i have not got the car on the deck yet to set the toes to 0.0. I had to have some custom springs made to get the sizes and rates i wanted I got them from D faulkner they do alot of Btcc stuff and nearly every historic race car.
                        Sounds exactly what we have in place
                        Purple fuel rail
                        Chef
                        • sandman1111
                          • Mar 2016
                          • 78
                          Do you have some more pictures of the exhaust?
                          • quattro-nick
                            • Sep 2012
                            • 1746
                            • Country: Belgium
                            nice car project james!
                            it looks that money is no object
                            TWINCHARGED power,zero lag
                            AEM W/M injection
                            • tubbylardo
                              • Feb 2016
                              • 12
                              That looks fantastic Terry. How much would something like this cost to have built? Was thinking of moving my AAH CQ on but having seen this I'm now having other ideas....
                              Andrew
                              Witham St Hughs, Lincolnshire
                              • 1998 Audi Cabriolet 2.6 V6
                              • 1995 Audi Quattro Coupe 2.8 V6 FOR SALE
                              • 2011 Vauxhall Insignia 2.0 CDTi
