01E Paddle shifting to S2
  • cmcraeslo
    • Sep 2016
    • 18
    • Country: Slovenia
    Hey guys.
    We're designing H paddle shifting mechanism (https://www.youtube.com/watch?v=wdrIiRBonr8) for 01E gearbox and currently have only the gearbox at hand. We did this conversion in the past, but since we don't have a any S2 car with us anymore, I need the measurements of the space between the gearbox and original tunnel. Any help would be more than appreciated.
    We will be converting a single rod to 2 rod using a converter (see picture). We will then connect the rods with actuators. We're still deciding (depending on the space) whether to mount the actuators individually or using actuator assembly box (like the one in the video).
    Thanks!
    Cool project. Can actuate the clutch with the pneumatics too?
    I can't help with the info you require unfortunately, but the gear linkage on the S2 runs along the side of the gearbox not on top & there isn't a great deal of space on the top.
    • cmcraeslo
      • Sep 2016
      • 18
      • Country: Slovenia
      Hey. Yes, clutch is also actuated with additional actuator. Basically it's a pneumatic/hydraulic assembly using master cylinder (pushed by the pneumatic cylinder) inline, just like hydraulic handbrake. There are two speeds that set the fast/slow release of the clutch, depending whether you shift up or down.
      • speeding-g60
        • Aug 2008
        • 1186
        great. now that i want to get rid of the dogbox and Audi motor, go to RWD auto and LS1 in the AWD CQ race car, this shows up. i like cool neat gadgetry... :-(
        • diesel des
          • 3896
          Cool. What sort of cost do you have in mind. Anything for a 03a box? Similar setup to 01e.
          • G60Rallye
            • Dec 2006
            • 1321
            That's going to be a brilliant project! Can the system be used on standard boxes or is it too fast for the synchros?
            • diesel des
              • 3896
              I suppose the speed can be adjusted with the controller to suit different synchro and gearbox types.
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                i like this but i do wonder what if there is something wrong with your gearbox,let says a bad syncro from 3 to 4 gear,the gearshifter has no feeling so is this covert to?
                TWINCHARGED power,zero lag
                AEM W/M injection
                • speeding-g60
                  • Aug 2008
                  • 1186
                  says "starting from 3500 Euro"..... i will pass.
                  Designed, machined, built, programmed and tested entirely in-house to deliver uncompromising quality, reliability and performance
                  • diesel des
                    • 3896
                    http://www.mme-motorsport.com/en/
                    Ahh yes not cheap...
                    • varia
                      • 821
                      • Current: United States
                      what would be the price that you think its worth it Aaron?
                      • speeding-g60
                        • Aug 2008
                        • 1186
                        its not a matter of worth, Chris. its a matter of "i am selling the dogbox, not rebuilding the motor in the awd car, and getting an LS-based motor and auto trans and going to do a reliable RWD turbo v8" now.
                        but at that money, it is well over what i want to spend ALONG WITH another $2500 or more to make this 4cyl happen. again.
                        • varia
                          • 821
                          ahh ok. i didnt have any clue about these thigns
                          thx!!!
                          • cmcraeslo
                            • Sep 2016
                            • 18
                            • Country: Slovenia
                            Hey guys.
                            Yes, not cheap setup. The thing is that high quality pneumatic parts are very expensive and there's a lot of development involved. If any of you should be interested, I'm pretty happy to offer individual parts and you buy/build your own setup with my help. I'm actually thinking of making this project open to everyone and just sell the electronics, but haven't really had the time yet to document anything.
                            Basically, you need two multi position actuators (with position feedback) with valves, compressor and a reservoir. Everything else is a matter of controlling the valves and mounting everything up.
                            • Thuppu
                              • 4115
                              Originally posted by cmcraeslo
                              Hey guys.
                              Fully undertandable that this kind of things cost. A diy kit would be a really interesting option.
