S2 Avant -93
It's still a mystery why someone did that. The cables have plenty of reach, but it was very hard to make switch fit into the center console with those extension cables
Is that mess because they couldn’t get the connector to reach or something?Leave a comment:
Now that the centre console is off, I decided to tidy up the switches. Before they were not in line with each other and it bothered the **** out of me
I've had spare switches for a couple of months and I decided to make my daughters nap time some use. Last picture also shows my recent discovery of previous owner(s) messes.
This gallery has 3 photos.Leave a comment:
Also a good thing it blew up on my driveway and not on the highway at 120km/h!Leave a comment:
I'm sure I the car will be back on the road by the end of the year
It's also kind of a relief that the nightmare with the steering rack is over and I can just install the used (hopefully working) rack to the car now. I know that I will lose the 2.6 turn fast steering, but right know it doesn't bother me too much TBH
Shame it did not work out after all the time invested. Hopefully the ebay unit will get you on the roadforum quickly to forget the hydraulic fluid shower ofyour drivewayLeave a comment:
Just had the worst day with the S2 so far.
After fitting the new seals to the rack it was time install it back into the car. Everything went as smooth as possible, and with all the hydraulics fitted, it was time to start the car the first time in three months! No visible leaks at first, but after turning the steering several times lock to lock, POP! My driveway was flooding with hydraulic oil. Immediately turned the engine off and went to see what happened. After brief examination, it was clear that the end cap had come loose. After three months of looking for correct seal kit, finding time to actually work on the car and spending many hours to get my steering back together, it was a major disappointment to find that the repair was not successful
My guess is that I never should have repaired the threads of the end cap. Live & learn
Already ordered used rack from ebay, hopefully it arrives within a week
Just a quick update, seal kit for the steering rack arrived together with the new evaporator. Assembled the steering rack and fitted the blower box back. I'm having problems with the evaporator connections however. The pipes from evap are not precisely the same as the old one, so the big pipe from evap to dryer is really giving me a hard time. Hopefully I can solve this by loosening the other end at the dryer giving the needed play. Dryer is behind the right wing and of course I managed to strip the threads of one bolt! At this point I thought it might be wise to leave it for now and try again tomorrow.You do not have permission to view this gallery.
This gallery has 2 photos.Leave a comment:
Let's hope so, it's been going nearly 300 000km and i don't know if it ever has been opened! Although I'm expecting to see some cracks on the cylinder head as many have written that thay are quite common. I guess I'll just have find out in the future
Internally I expect you will be pleasantly surprised. More likely plastics on sensors etc will be more of a problemOriginally posted by AntsaIt's not the most pleasant job to do but hopefully the new flaps will last for years to come. I have learned that when you take something apart you most certainly will find something broken that you didn't know about. Like the AC evaporator. I wonder what I will find once the engine comes out
Sent from my XT1562 using Tapatalk
Heater flaps seem to be a common failing with the age of most cars now and will be a common job on peoples lists over the next few years I think. I had to do mine and the matrix this year tooLeave a comment:
While waiting for my OE steering rack seal kit to arrive (found it on eBay!!), I took the dash and ventilation box out. I was getting very little to no heat inside when weather was cold. Since the heater matrix is relatively new only possible cause left were the rotten flaps inside the vent box. After opening the box it was obvious that the flaps needed to be redone. As I could not find any self adhering foam, I had to use black upholstering cloth. It's same that's found on speaker boxes etc. Of course there was something broken to be found, in this case it was the AC evaporator. Luckily they can be found quite easily even these days, so I ordered one with some new o-rings
Now I just have to wait for it to arrive and then put it all back together and enjoy the hot air coming from the vents
This gallery has 5 photos.Leave a comment:
Lately I've been struggling with my steering rack but its slowly going back together. I managed to repair the threads of the end cap with a thread file. Now the cap screws on just fine. Only thing I'm missing is the grooved o-ring support ring for the cap, but I'm getting close to the solution. Hopefully I can then put the whole steering rack back together and install it back to car.
I also bought new exhaust manifold from the RS2 Evo group purchase. Big thanks to Jonas_R for organizing it!You do not have permission to view this gallery.
After closer inspection I noticed that the threads of the end cap were totally ruined. Since local machine shops were not too keen on repairing the threads, my option is to look for a good used quick steering rack or finding a casing that has its ens cap intact and use my original internals.
So if someone has a working rack or just a bare casing for LHD car, please PM!You do not have permission to view this gallery.
This gallery has 1 photos.Leave a comment:
