... Violent weight transfer to rear doesn't help, will be quicker once suspension is sorted out.
s2 full repainted and new tuned rs2 engine
since a long time , am back here
the s2 is lowered now with an h&r cupkit ( bilstein shocks)
am looking for an new turbo , i guess a garrett GT35R
today i started with changing my gearbox
grtz allsee my s2 to rs2 conversion on www.verle.beComment
if this was a movie it would have xxx rating sex on wheelsOriginally posted by area51-s2-belgiumsince a long time , am back here
grtz all
2. PORSCHE CAYENNE CALIPERS
3. H & R SPRINGS
4. BILSTEIN SHOXS
5. NEW BUSHES AND HP2 STRUTS
8. fmic fittedComment
that should say sex on wheels but when you have fingers like sausages it's sometimes hard to typeOriginally posted by topsparkyif this was a movie it would have xxx rating sewx on wheels
1. SHORT SHIFT KIT
3. H & R SPRINGS
4. BILSTEIN SHOXS
yes finally my old S2 ABY engine is gone and guess what i have in return
AUDI S4 blok (99-01)
265pk 400NM V6 DOHC 2.7 bi-turbo
is someone intrested in buying this or do someone knows a audi s4 avant with a broken engine
maybe i can swith this with someone who can help me on parts for my upgrade from 380hp tot +500 ?
nono it's not for in my s2 , but it can be done , i have seen it ,have photos somewhere , but indeed hell of a job heheOriginally posted by SweeperYou found a nuts engineer who will put that into s2 ? =]
no it's ideal for putting it in a audi 100 or 200
or if i can find a s4 with a frontal accident ...
grtzsee my s2 to rs2 conversion on www.verle.beComment
i decided that my cheap TSW wheels not longer fit on my restaurated s2 with brandnew tuned rs2 engine , so i searched for new ones .
today I ordered new wheels
BBS RX 17"
try to order these tyres but non available in 225 45 17
BRIDGESTONE RE540S Potenza
so i probably will order these :
Yokohama Proxes R888
anyone has experience with these ? or other sport tyres ?
Yes, i use Toyo Proxxes R888 for everyday use.Originally posted by area51-s2-belgiumi so i probably will order these :
They are quite stiff and noisy to drive with in regular traffic, but once out on the track, you have unlimited grip (it seems), and they do last a bit even with hard handling/use.
The sidewalls are extremly stiff and the compound are medium to hard mix i would guess. The "V-shaped" pattern also makes a lot of noise crusing in low speeds, and the handling on wet surface is not very impressive (but very very fun!). The braking is superior infact!
If you are after a comfy sport tyre i would not reckomend this, but if you are after a good grip/low price and legal tyre for clubsport/trackday use, i would reckomed it.
Anders - S2 Avant Clubsport - 8pots or die!
*My Dream* is to do this whit my Audi Coupe
