Spotted a nice green s2 avant today in Findon Valley near Worthing. I gave u the thumbs up im pretty sure u saw me i was in the dark s2. Is it anybody on here?
Spotted S2 Avant!
that was me - about 30 seconds from my front door! - I saw you, but too late to wave...... - We were on our way to friends in Lincolnshire for a couple of days - so the diff locks came out to play.....
Ian85 WR Urquattro, 85 20vT International liveried RallyRep
93 MTMS2 Avant
Ian didnt u have a UR to? Was u at a mini meet a while back at the star pub in leatherhead? I was going to the nans for xmas lunch, she lives in goring3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
(just need the RS2 Airbox)Comment
That's me, the mini-meet was at The Star in Malden Rushett - Still got the Ur - although it's in need of a manifold in the spring...
doesn't do much in the winter anyway, so I'll wait a bit to get it fixed. The S2 I still use for business mileage so it get's everything it needs.
I've yet to find a better car for the job!
93 MTMS2 Avant
I was there with the early Y reg UR Quattro red one. Its in my profile. What one was your UR? Mine needs the engine mounts doing but again i dont use mine much so i will wait for that. Any idea if the engine mounts are a hard job or would i mechanic be able to do it3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
This is our ur -
and this was the meet at The Star in May
Is that your red'n Steve?
93 MTMS2 Avant
Yeah that was mine on the end the y reg. Was thinking of selling it but then i saw the error of my ways and realised i had a great example of a classic fantastic car. Need the mounts doing any advice u can give? I have been quoted around 450 is that realistic?3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
I have not got a clue what im doing so i would not be giving u much of a hand
. I was quoted 70 for the mounts each which i think is main dealer price but quattro corner quoted me a lot less than that. How hard a job is it? i heard there are four mounts three are quite easy but theres one when u need to remove the metering head is this true? thanks for your help
Mounts are about £40 each from Pete @quattroCorner, the engine has 2 mounts and then there are 2 for the gearbox. Quick test to see if your engine mounts are gone (especially the turbo side) (this is only ur specific), open the bonnet and place a finger on the slam panel pointing towards the camcover, if the top of the cover is below your finger then the mount under the turbo is shot.
The one under the turbo/metering head (IMHO) is the easiest as once the metering head is moved out of the way and the headlamp is removed you have perfect access to it.
It would be a pleasure to help.
It certainly isn't going to cost you £450!!!Corey
01636 822288Comment
Cheers mate thanks for your offer. Ill get the mounts from quattrocorner then ill be in touch if i can get up north. I have had them checked out and apparently they need doing. The engine is rocking forward and the front pulley is catching the radiator hose and cutting through it. Have u come across this before.3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
You mean the aux rad hose? Then yes, if funds permit I would advise swapping to the Dialynx main radiator as it allows you to do away with the aux and the costly bottom hose and is a nice looking piece.
Be aware the longer you leave the mount, it will be putting undue strain on the exhaust manifold, which does lead to it cracking.
In the image you will see the rad, please ignore the rest of the engine as this is before we started upgrading and it doesn't look anything like this anymore, it will look better
Attached FilesCorey
01636 822288Comment
yeah thats what i was told so i have not been using it much, also the MOT has just run out so i have decided to take it off the road for the moment.3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
@Corey do u think a good mechanic that has not worked on quattros before be capable of doing the mounts without messing anything up? The reason i ask my brother went to many people to get his car running properly and spent a lot of money before finding qst where he finally got it sorted. I dont want that happening to me. cheers3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
