608hp on the dyno
  • zlobo
    • 967
    608hp on the dyno
    Andreas managed to pullout some power
    here is the video klick here "save as"
    ABT C5 Lord Of The Rings
    2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
    2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
    2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
    kostic.nu
  • Doug_RS2
    • 3847
    what spec is that car?
    608.8ps = 600.46 bhp
    • S4turbo
      • Nov 2005
      • 81
      • Country: Norway
      Great numbers, do you have any specs on the engine?
      J
      • zlobo
        • 967
        J
        original pistons,
        verdi rods
        nira fuel managment
        runs on E85
        camshafts, ported top, precision turbo.
        and so on.
        kostic.nu
        • Ducky
          • May 2006
          • 636
          That almost looks like a version of the Ross manifold made to suit. I'm toying with either going that route (using one of the 20v flanges) or the wagner route...
          • Billman
            • 4129
            Yes, the manifold is interesting. Can we maybe see some pictures of the Engine underside?
            Go Holset or Go RS4
            • Mark Halligan
              • 2001
              Do you know what type of velocity stacks the manifold has? They look like they have a nice taper to them, similar to the ones I have in my IM.
              Great Dyno numbers
              Mark - Modded
              • zlobo
                • 967
                11.51
                blacrace
                kostic.nu
                • Ducky
                  • May 2006
                  • 636
                  Zlobo, is it possible to get an actual list of the engine mods that were made (make/model of turbo/exhaust manifold and so on)
                  That's the sort of power I'd like out of my ABY project, so it would be helpful to know what has been done (comp ratio/boost etc)
                  Many Thanks
                  • Ducky
                    • May 2006
                    • 636
                    I think they are the Ross velocity stacks (hence my comment earlier), looks like round to oval.
                    • zlobo
                      • 967
                      msd 1000cc injectors, verdi rods , original pistons, other profile on the cams, harder valve springs (ford crossworth), em and im, nira mgmt system, turno is a PTSC61 with ar .63 on hot side.
                      those funnel in the intacke are pressed by one of his frends 38mm iner dia anf 68mm at the bigest.
                      one thing more he is runing this on a standard 5 speed gearbox.
                      kostic.nu
                      • djcnp
                        • Apr 2004
                        • 25
                        Nice Zlobo.. im the Editor of the movie=) tomorrow i will go and get his old cams...
                        Audi s2 1992 "SilverArrow"
                        1/4mile: 11,54 @198 km/h
                        1/8mile: 7,39@156 km/h
                        Audi s2 1991 "The TOB"
                        Under Construction
                        • zlobo
                          • 967
                          oki. but wy not anything beter than those? i think he made copys of addes old cams and matsson mejuerd those and he thinks its 7a mjure the lift on them.
                          kostic.nu
                          • djcnp
                            • Apr 2004
                            • 25
                            Well they seems to work good for my goals... you dont get 608hp with bad cams
                            Under Construction
                            • zlobo
                              • 967
                              i did not say that they was bad, i runed my self on 7A and i think they work great. a bit agressive on the top end.
                              add:
                              By the way when are you going to post youre project here?
                              kostic.nu
