Why? Car was designed on the stock gearbox ratios to do approx a 160mph and slow down from that on the standard brakes. Whether you have 230hp or 1000hp it still takes the same effort to slow down from 160mph. Big brakes is for track cars that want to stop as late as possible going into corners on a repeated basis. If a road going car then it's neither here nor there so long they are not smaller than stock.
Is this car anyones on the forums? 700+hp
So if you make alot of power and can reach a higher terminal speeds quicker you dont need bigger brakes to stop you?Why? Car was designed on the stock gearbox ratios to do approx a 160mph and slow down from that on the standard brakes. Whether you have 230hp or 1000hp it still takes the same effort to slow down from 160mph. Big brakes is for track cars that want to stop as late as possible going into corners on a repeated basis. If a road going car then it's neither here nor there so long they are not smaller than stock.ChefComment
More to the point the standard brakes are inadequate in the first place.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
My ufo brakes hold very very good ,and the car is not standard.I took a friend of mine wich owns a new impreza wrx sti(300hp) in the car and we made few runs and he was impressed by the breakes .I agree that on a track day you definitely need upgraded breakes!Comment
