What a V-stream RS2 remap delivers against a Merc E63 AMG
  • Avantus
    • Sep 2007
    • 941
    • Country: Belgium
    #61
    Indeed I had never felt that before.
    With V-power and around 10°C yesterday eve against that AMG... boy it does make difference
    these were a different league
    And yes, that is a GT2RS and new McLaren in the back!
      #62
      Agreed on fuel related stutters... V-power is superior fuel. I would like to dial out some timing on a revision of the V-stream so it runs sweeter on 97 or 95 fuel - it wont be as aggressive of course but will be better.
      Avantus - pls remind me again what boost levels you are actually seeing at 4000 and 6000 on your RS2 ?
      • AndyP
        • 6049
        Was that a magazine photo shoot?
          #64
          'k me that is an expensive looking layby
          • Avantus
            • Sep 2007
            • 941
            • Country: Belgium
            #65
            CAR magazine
            And i'll have a look for some exact readings about those boost figures Paul
            • prj
              • Mar 2010
              • 6308
              Avantus, do you have a VAG-COM cable with which you could log a 3rd gear pull?
              • Avantus
                • Sep 2007
                • 941
                • Country: Belgium
                #67
                My mechanic has, I could ask him next time
                  #68
                  That would be great alright - log of Groups 0, 2 and 3 would be nice...
                  • EspenW
                    • Apr 2007
                    • 1534
                    • Country: Norway
                    #69
                    It says 26°C on the plot
                    357° is corrected, 362hp iirc measured. 312hp at the wheels.
                    Must have been extremely high ambient pressure if a reading at 26C is adjusted down. Nice figures for just a remap, though. 312whp means 13.8% drivetrainloss, and that is not happening on a quattro drivetrain, so it could very well be that real crank HP is higher (or the dyno reads high for whp).
                    Dyno numbers only tell how hard a car pulls at one (or two) points in the rpm range, though, and a car with lower peak numbers and more average hp could easily be faster on the road, as it seems that your car is.
                    Get/borrow a Racelogic Pbox or a G-tech for that matter and do some 100-200kmh pulls on the Autobahn. I think it should pull some rather good times.
                    1994 80E Avant
                    1986 2L Golf 2 on Alcohol
                    • Avantus
                      • Sep 2007
                      • 941
                      • Country: Belgium
                      #70
                      It was indeed quite hot last thursday. And I've got a decat 3" exhaust with stock downpipe. I also thought that 14% losses is quite little, but since I saw the car being rolled out, I presume that reading should be accurate... MRC's bench should be one of the better ones. I think it was 311whp first run, 312 second run.
                      my speedo is accurate up too 3-4km/h on 200km/h (like most RS2 dials), and 100-200 is around the 10-10.5 sec area starting in 3rd gear. I'll have to borrow a Pbox from someone to be sure yes
                      • prj
                        • Mar 2010
                        • 6308
                        Only Group 2 is really interesting for me.
                        But don't log all groups together, the sample rate will be uselessly slow.
                        Also, 312 whp is high.
                        That figure is fairly useless anyway without knowing what other similar cars pull on said dyno.
                        360-370PS (PS vs HP...) has always been "good remap" territory. Your DIN corrected CHP (or CPS) number shows that you are on target, that's all that's important.
                        With 1.3 bar at 7000rpm it's more like 400hp territory, and RS2 injectors don't hold that.
                        I also really don't like "approximate" information. Like looking at gauges instead of having hard data in logs, timing 100-200 runs with a stopwatch and speedo etc.
                        Experience shows that such measurements magically enhance the numbers.
                        Such is the nature of man.
                          #72
                          Agreed that Gp2 is most useful if you have to single one out - pity we can't make that link faster !
                          From memory - this setup should be circa 1.2-1.3bar at 6000rpm... will be interesting to see IPW up there... expecting 17-18ms off top of my head.. accounting for 85-90% IDC if you do the math.... and just enough headroom for latency
                          IDC % = IPW * RPM/1200
                          where IPW is expressed in milliseconds
                          • EspenW
                            • Apr 2007
                            • 1534
                            • Country: Norway
                            #73
                            For maximum VAGCOM sample rate:
                            (from Ross Tech):
                            In order to get the highest sample rate possible go to the Options screen and set Blk Int to 25 and Char Int to 0. Note, however, that this may cause unreliable communications with some controllers. Changing KP2 time to a smaller value speeds up the sample rate in Measuring Blocks on control modules that use the KWP-2000 protocols. Try setting it to 0. If any of these adjustments cause unreliable communications, change them back closer to the defaults. If in doubt, use the Restore Defaults button!"
                            1994 80E Avant
                            • prj
                              • Mar 2010
                              • 6308
                                #75
                                Espen - legend... saved me an hour or few I was going to try to find today and experiment on just that here. Cool !
