What a V-stream RS2 remap delivers against a Merc E63 AMG
  • EspenW
    • Apr 2007
    • 1534
    • Country: Norway
    #151
    Originally posted by AndyP
    If I take the gear change out of my time ( 0.8secs ) it brings it down to 3.6secs, this is 60-90mph not FATS, and I don't think mine is producing anywhere near that HP, but it is 200Kg lighter.
    Often hard to estimate in gear time vs. a 2-3rd shift, but if you shifted at 65mph, it definitely hurt the 60-90 time. You were still faster than a B7 RS4 using 2nd and 3rd, though... and they shift at 70mph+
    1994 80E Avant
    1986 2L Golf 2 on Alcohol
    • EspenW
      • Apr 2007
      • 1534
      • Country: Norway
      #152
      Originally posted by prj
      Wrong.
      On I5 the cc@3 bar shows approx how much power the car can make with the injectors at 4 bar. Around 360 is all that RS2 injectors can make at 3.8 bar, and this is not with AFR's around 11, more like mid-low 12's.
      You have a very good corrected dyno figure of 360 PS. This is realistically what remapped RS2's make. On the same dyno a 3071R 0.82 car made 430 PS on stock engine, which is realistically what it makes and the IDC on it matches that.
      Why all the useless discussion and virtual dyno plots and speculations when the car was measured on a dyno known to be fairly accurate and of which we have lots of graphs for similar cars?
      Who even cares what it makes - just enjoy it for what it is.
      True about the base fuel pressure.
      However, the owner indicated that it wasn't running correctly on the dyno and that it has picked up considerable power with the proper fuel. The whp reported by the MRC dyno isn't corrected for ambient (only the estimated crank figure is), so if he pulled 312whp on a dyno on a 26C day with bad fuel, 331whp on the road at 18C and proper fuel should be rather correct.
      What it shows is that a remap/exhaust only car can be as fast as a 520ps E63, much faster than a 460hp B5 RS4, much faster than a 400hp Hohenester K26/27 RS2 and even faster than a 430hp RS2 running a 480hp Turbonetics turbo.
      It will even be faster than a 480hp Porsche 997TT in a 3rd gear pull.
      This should make a lot of folks rethink if they should bother going past the remapped RS2 stage. They might pick up more peak hp, but the car might not end up faster on the road
      1994 80E Avant
      • A80Avant
        • 10873
        • Country: Greece
        #153
        very true, but on the road, you dont end a run on a 3d gear, and that is where the whole 'run' is lost, cause you may be able to keep up with a faster car, but how do you know that the other car is not pushing the car all the way?
        I ran against an R8 once when i was on the 3071R setup, and i could easily keep up, and overtake, but in neither case did we actually spoke to give full beans, so no way of knowing.
        Its been said before though that a mapped totally standard RS2 with a refurbished engine will do wonders.
        • Avantus
          • Sep 2007
          • 941
          • Country: Belgium
          #154
          Thanks for the charts and info EspenW. Very high results, with ofcourse a non verified weight input. Still believe my turbo is stock, but my 3" freeflow decat exhaust certainly got the best out of it. I've also got my doubt with those high numbers, but FATS and other results are true facts... I actually DID buy the cables & soft yes
          FATS is as said pretty limited in its measurement, but is still a cool way of comparison. And no stopwatch stuff, but pretty precise measurement.
          Took out another time from the logs. As stated they might have some lag on them, but it's better then stopwatch, and they are GPS verified.
          80-180 starting in 3rd gear with a normal shift into 4th is 9.92sec. Guessing closer to mid 9 with a faster shift without having to build all that boost up again.
          • EspenW
            • Apr 2007
            • 1534
            • Country: Norway
            #155
            A third gear pull will take you to 100mph, and in my opinion, that is high enough speed on a public 4 lane freeway (means jailtime on these shores). Track or autobahn is another story, though. In those cases, the car with more peak hp will start to pull away after it regains boost in 4th.
            In gear acceleration numbers from magazines is the best way to get an idea of how you will stack up against different cars for a 60mph pull to 90 or 100mph.
            Avantus' car will do 60-90mph in approx. 3.2s
            Here are some rather nippy cars that have been magazine tested in the 3.1 to 3.3s range for 60-90mph:
            Nissan GTR/Mercedes SLS/Audi R8V10/996TT RUF/Ferrari 430/BMW M6/Ferrari F50/Ford GT
            If it was a R8V8 that you had a pull against there is no wonder that you could easily keep up. They have been tested to 11-13s range for 100-200kmh, yours is low 9s and that is by using 4th gear only.
            1994 80E Avant
            • Avantus
              • Sep 2007
              • 941
              • Country: Belgium
              #156
              best 60-90mph is around 3.7sec according to vagcom time vs speed, not 3.2. Would be pretty insulting for all those supercars you are stating
              • EspenW
                • Apr 2007
                • 1534
                • Country: Norway
                #157
                Cool. Stock RS2 did 80-180kmh in 18.9seconds when tested by AMS, so that remap boosts power by quite a bit, as it almost doubles available tractive force during this speed range
                See if you can do a in-gear 4th gear pull from 100-200kmh (when conditions allow of course).
                1994 80E Avant
                • EspenW
                  • Apr 2007
                  • 1534
                  • Country: Norway
                  #158
                  I would not pay too much attention to the vagcom speed reading. FATS time should be somewhat higher than real 60-90mph time as the speed range (real) is slightly longer.
                  With your gearbox/tire size, FATS is 57.5 to 89mph, so it covers a range of 31.5mph.
                  1994 80E Avant
                  • prj
                    • Mar 2010
                    • 6308
                    The whp reading on that dyno is not standardized. This is why the CHP loss is so small.
                    Lol.
                    Whatever, you guys keep thinking that RS2 turbos run 330 whp. Or perhaps I am just horrible at mapping cars, because I have to work really hard to get 330 whp out of a 3071R/0.82 and for that I need bigger injectors than 440cc, because the 440cc's max out for me.
                    I'm done.
                    • EspenW
                      • Apr 2007
                      • 1534
                      • Country: Norway
                      #160
                      Lol.
                      According to Doug, their dyno measures true wheel torque and adds the run down losses.
                      Dougs own words from another thread:
                      "Before anyone goes on about losses, these dynos measure the torque applied at the wheels on a power run then will measure the torque on coast down"
                      The Mustang correction factor for the VD is 0.95, so a 330whp VD number becomes a 314whp Mustang. Ambient corrected figure is even lower since 18C is lower than standard conditions. Also, the 1630kg weight is only an estimate. Real weight is probably lower, meaning an even lower hp figure.
                      BTW, what kind of 100-200kmh and 4200-6500rpm times have you logged on the 330whp 3071 cars?
                      1994 80E Avant
                      • prj
                        • Mar 2010
                        • 6308
                        I haven't logged FATS.
                        But you can ask hoffer76 to do that, as his car measured 430ps on that dyno. Stock RS2 with injectors, turbo, pump.
                        • EspenW
                          • Apr 2007
                          • 1534
                          • Country: Norway
                          #162
                          What about 100-200kmh or 100-150kmh?
                          No 3rd gear Vagcom logs at all?
                          How about vagcom 3rd gear logs from stock RS2 setups or remapped ones?
                          1994 80E Avant
                          • AndyP
                            • 6049
                            As I thought, leaving it in 3rd resulted in a 60-90mph time of 3.7sec or 4.7sec in 4th.
                            • EspenW
                              • Apr 2007
                              • 1534
                              • Country: Norway
                              #164
                              Cool. Should be room for great improvement when you get things sorted out
                              Still, it is almost as quick as a MTM 460hp B5 RS4 that I tested (3.65s in 3rd and 4.54in 4th) and 0.3s faster than a 400hp Stage 5 Hohenester RS2. These were heavier and also tested with passenger, but it seems that you are making decent power already.
                              1994 80E Avant
                              • AndyP
                                • 6049
                                Just been studying MRC's FATS database again and wondering how much the B5 S4's and RS4's weigh as the ones quoting 3.7sec FATS times are between 430 and 460bhp
