Motronic 2step with ALS
Tags: None
HX35 with big hotside, the car has more than 450 hp.
But the boost is adjustable... the same turbo can do over 2 bar also on the launch control.
I think even the 1.7 is a bit too much because he has no traction at all in 1st, maybe dial it down to 1.3 or so.Comment
So left foot braking and right holdind gas should be the only way for power needed in corner exit orscandinavian flick?Because with normal setup you brake,transfer weight and power is delivered a little to late.A na 2.3 is more fun to flick..Comment
There must be something that you can do about that,i am shure
I can find a way of getting controlled fresh air into im with throttle closed or creating a mechanism that keeps throttle opened with als on and closed with als of.And a new electrical contact that will tell "your" ecu that throttle is of even if it is not fully closed.And you can try to get the timing,fueling and map switching?
It is possible that motronic will accept so timing?
I also think that with als on(if throttle is mechanical kept open) ecu will see a problem with tps if it reads "throttle opened 20%" lets say,even if closed throttle switch is activated?That also could be altered by mounting another tps in parallel with stock one for the ecu to use it in als mode
I may be a dreamer...But i do not imagine what brakes will hold to left braking while right keeps boost.Comment
Last edited by Vauhtiveikko; 30 September 2012, 20:26.S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85Comment
You can tell me those crazy ideas in Romania over a beer sometimeThere must be something that you can do about that,i am shure
It looks to me that you have to wait too long for boost.
I am using only rev limiter, no fuel enrichment or ignition retard.
Every time i press the clutch pedal the rev limiter is 5800 rpm. With this setup i dont have to switch of launch control from the button. I am using every day this combo. Also i am flat shifting with this conf also, boost dosent drop below 1.5bar.
I dont need more than 0.5-0.6 bar to launch correctly.
From here you can see and hear that i rev under a second in start and i have to correct the steering because i allready have wheelspin. If i have over 1.0bar boost in start then 60ft was 2.0-2.1sec because i had too much wheelspin.
My 60ft are 1.8-1.9. I think it aint bad for ~1800kg car.Audi UrS4 609hp/846Nm @ wheels
10.911@210, 1km 268km/h, 1mile 295km/h
FATS 2,30 secComment
