TTRS I5 720 horses and flames
Tags: None
Engine:
5-cylinder Turbo 2.5 liter
Power: 598kW (814 HP)
Torque: 1.000+ Nm (dyno limit)
Radiatorless Water System
Exhaust Gas Temp. 351°C
No catalityc converter needed
1.850 rpm - 115km/h - 5.3l/100km -
what a waste! (keep watching after the dyno)
HOAX. Those numbers do not add up.http://www.youtube.com/watch?v=vVnM8...ayer_embedded#
Engine:
No radiator needed so the engine needs to dissipate 60kW of cooling energy by a looped hose?
Running lean burn to keep temperatures down and increase efficiency? Not in this world!
Running that kind of low temperature levels needs alcohol-based fuels, which will not make those low reading BSFC numbers let alone future CO2 emission levels.
And that only by swapping an IM, valve geometry & piston bowl design, non-DI, ...
Reciprocating engines are mechanically not very efficient and never will be, nor is burning stuff in this world.
http://www.rtugroup.com/animation
Is that the most effiecient way to burn fuel and convert the stored energy inside it?
Angus
(1984 ur quattro)Comment
does look very much like it's exotic fuel like ethanol with the blue flames though.Volcano ABY coupe
AntComment
Maybe you guys would like some HHO generators to go with that?
I have an even better idea.
PMSL!
Defanitly
in essance, id guess so.
this vid had been covered on a couple of other sites and everyone says its fake, giving various reasons, but if you watch the vid on the dyno, the live data doesnt correspond to their proclaimed data, i.e coolant temps, 35degrees.......actual 82 degrees on the screen etc1993 URS4 Avant Emerald Green 350+bhp
