Washer for main crank pulley
  • bernsaudi
    • Feb 2007
    • 592
    Hello, anyone got one? Thanks!
  • rxl
    • 1913
    i have one
    • bernsaudi
      • Feb 2007
      • 592
      Does anyone know whether the AAN engine also uses this washer ?
        Yes the washers as the same on AAN, 3B and ABY
          Just ABY, ADU & later AAN. I think the early AAN pulley doesn't use it, but later ones do....or maybe its vice versa can't remember off hand
            Thanks for correcting Alex. Any idea why it wasn’t used on 3b and early aan?
            • mac2226
              • Jun 2008
              • 1289
              There a expensive washer I know that, could it be the dampr distance has something to do with it?
              • bernsaudi
                • Feb 2007
                • 592
                I found a vw washer 074 105 193 same size for a tenner, not blooming 60!
                • twoqu
                  • Sep 2003
                  • 3103
                  The TDi washer is only 0.13mm thick which is considerably less than the correct one!
                  • bernsaudi
                    • Feb 2007
                    • 592
                    Ah yes that is much thinner, scratch that then!
                    • twoqu
                      • Sep 2003
                      • 3103
                      Yep! Its nearer 3mm thick according to this post:
                        EDIT - wrong thread
