01E 6spd S2/RS2 shift linkage
  • 01E 6spd S2/RS2 shift linkage
    Looking for a 6spd shift linkage from an S2/RS2 to do a FWD 6spd conversion on my cabrio (have just sourced an ARX box from C4 2.5TDi)
    Ideally the whole lot, shifter, linkages and the spider from the gearbox if possible
    Thanks!
    I have the spider, the shift lever, gear knob and new OEM rubber boot for the bearing. The 2 parts of the linkage I have are no good.
    If you find the rods, maybe is useful to you...
      Definitely interested, as I've not had much luck finding any of these bits...
      I did get the gearbox side of the shift linkage with the ARX box, but highly doubt they will fit the B4 chassis .
      How bad are your linkage bits? Could I use them to get dimensions to make up new rods or use the connection ends?
        Are you in a rush? I have a new batch of my 6 speed linkages coming in 4-6 weeks
          No rush, this might end up being the best way forward and avoid a whole load of adjustment cutting and bending - what does your linkage include?
            It is a complete bolt-on linkage based on the B5 and later 3 rod system.
              my advice... go with this....
                I'm thinking that also, it sounds very promising!....Not sure if I need a spider or shifter (mine is 5spd) though?
                  Nope, you won’t need any existing linkage parts, my linkage is a complete bolt-on
                    might need a knob.....?
