S2 ABY Clutch Kit. Normal or race or adapters etc
  • HuwSy
    • Apr 2011
    • 181
    Hi. I’m after a clutch kit for my ‘95 ABY S2 or adapter to the urs4 kit or part numbers that are available somewhere or any combination that gets it working again. Thanks
  • HuwSy
    • Apr 2011
    • 181
    Would the rs4 clutch kit from sashs 3000951848 fit in any way, it has the same hub profile, diameter and teeth count? Or would I need to change more to fit?
    • Mikes2
      • 1704
      You can have my old one if it's any use. Came from an ABY avant with 110k. Message me you're interested
      Mike
      http://www.s2-audi.co.uk
      • HuwSy
        • Apr 2011
        • 181
        Thanks, but looking for something new or almost new. Mine has come out at about 100k but needed bearings in the box so trying to buy myself some more time before having to have the box off again.
        • Mikes2
          • 1704
          You can get the clutch friction plate re-lined which in the absence of parts being available new, may be an option.
          Mike
          • HuwSy
            • Apr 2011
            • 181
            I may have found a new dead stock one from the Netherlands or if that isn’t right may have to look into resurfacing. Sachs performance seem to also be an option although an expensive option when I’m only running standard power and as a daily driver.
            • HuwSy
              • Apr 2011
              • 181
              Seems the dead stock couldn’t be found when it came to go in a box. I may have found a Sachs performance on order from Germany and was the last in stock. The other option is helix will make them to order but take 15 days to produce but might be easier to sort than resurfacing in some cases.
