Speedo Required
  • madpugger
    • Sep 2007
    • 1901
    Speedo Required
    F**K! Just wrecked my spedo changing to plasma gauges. Anyone got a spare?
    Le Mans 2012
    Nurburgring 700
    1995 S2 Avant
  • topsparky
    • Oct 2005
    • 2014
    vagparts do them mate
    is the s6 one the same as the s2 coz i have a spare on of those
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
    • Nuvo
      • Nov 2003
      • 3825
      They're completely different I'm afraid.
      • Acidburn
        • 13459
        Vagparts is the same price as the rs2 one's if you look on there website I gotta pick a brand new one up in the morning for on mine.
        Let me guess you removed the needle which is spring loaded? Martyn warned me about that which is why i've got a full unit coming for mine as you cannot just get the faces.
        • madpugger
          • Sep 2007
          • 1901
          YUP, just tried to rewind the motor but the wires got all tangled Don't suppose I will get one before christmas Unless you are up aberdeen way in next day or two?
          Le Mans 2012
          Nurburgring 700
          1995 S2 Avant
          • BRY
            • 3755
            Can't you use an ordinary black one if you're fitting plasma faces to it?
            • madpugger
              • Sep 2007
              • 1901
              I am not sure, would a less than 160 MPH one work?
              Le Mans 2012
              Nurburgring 700
              1995 S2 Avant
              • Acidburn
                • 13459
                Unfortunately not i'm only going as far as ipswich area
                IIRC vagparts would take about a week to get them in but being christmas would be a pain, especially considering you only want it to put the plasma's over the top.
                Can't you get hold of a v6 or 20v one tbh i'd have thought apart from the gray face that they'd be the same
                • Acidburn
                  • 13459
                  the v6 and 20v one goes up to 160 iirc? I'm not at my machine atm otherwise i'd check etka
                  • madpugger
                    • Sep 2007
                    • 1901
                    Does it need to be 160 tho? are they not all calibrated the same with diff faces?
                    Le Mans 2012
                    Nurburgring 700
                    1995 S2 Avant
                    • Flat on my back
                      • Jan 2007
                      • 2449
                      20v one does, still got the speedo plus other bits from the binnacle You supplied Mr. A
                      Any use to ya?
                      Carlos.
                      • madpugger
                        • Sep 2007
                        • 1901
                        That would do me! how much? and when could you post it?
                        Le Mans 2012
                        Nurburgring 700
                        1995 S2 Avant
                        • Flat on my back
                          • Jan 2007
                          • 2449
                          Which bits do you want?
                          I can strip out all 4 dials plus the mechy bit at the back?
                          Up to you?
                          Carlos.
                          • Acidburn
                            • 13459
                            Lol forgot about that speedo dial you had off me
                            • madpugger
                              • Sep 2007
                              • 1901
                              Hmm, let me see, i will try remove the rev dial first!
                              Le Mans 2012
                              Nurburgring 700
                              1995 S2 Avant
