Please... if somebody has a set for sale... let me know.
For the moment..a friend off mine.. Nemilosu..member of this forum is running with 3B ones in his AAN because the engine was bought with 3 types off injector on it... only 1 was AAN original.
Thank You very much!
All the best!
Eugen
the 3B ones can fuel more liquid than the ABY/AAN injectors true??? maybe 3b ones are better... i am not sure,but i think that i´ve read this someday in some place...
RED Mitsubishi Lancer Evolution VI TME nº 16 of 250 BLACK Mitsubishi Lancer Evolution VI TME nº 189 of 250
Yes.. you are right.. the 3B running at 4 bar...AAN pressure flowes more than aan oem...but..He has AAN ecu with stock chips and AAN ones have 4 holes.. beter atomisation..i understood..Now running these injectors(3B) has an average off 24 liter for 100 km consumtion...i dont think is ok.
Maibe with a remap??? But too expensive for such a thing.
You understand what i mean.. no?
Dont know what to do?
Thanks!
Eugen
You need 5 injectors of the same type at least. I hope you get some soon!
'93 Audi S2 Avant panthero black, 412.000km
'94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
'93 Audi S4 C4 Avant, 260Tkm
'88 Audi 100 Avant turbo 44Q
'84 Audi 80 quattro tornado red
For now is running ok with 3B ones... but high fuel consumtion and no power as it should. I think lambda can make the adjustments in fueling.... but is an S..no?
I hope that with the oem injectors will be like a good AAN engine.
Thank You!
All the best!
Both the 3B and AAN/ABY injectors are rated as 320ccm - at different fuel pressure.
The 3B ones achieve that at 3.5bar whilst the AAN/ABY uses 4bar to get there...
Indeed - the 3B ones have single hole outlet and the story goes that AAN/ABY jectors provide a better atomised and improved spray pattern by having four holes on them.
3b ones are 320cc at 3,5bar....the same as aby/aan but at 4 bar...
and if calculate 3b ones at 4bar with for example the 7A FPR... can make 365´7cc... it´s just the same as the oem RS2 injectors at 3 bar true?? maybe are enough for a stock cars (of course) and maybe too for cars with 340-350hp
good luck Eugen
thank you eugen and thank you guys.
indeed,i think the consumption it too big 25l/100 km.
i like pedal to the metal but i dont feel the engine running like a aan or 230hp.
if i do a remap someday i'll ask what is better : injectors from 3b or original aan's
until then..............................
Thanks guys! I allready speaq with Nip... I just hope i will e able to send him the money because Paypal is not working in Romania.
I will let you know for sure how this will end.
All the best!
Thank You!
Eugen
