Water manifold to turbo pipe
  • europeanme
    • Oct 2005
    • 3817
    Having narrowly avoided blowing my turbo up as the above hose was hanging on by a thread. It is proving not the easiest item to get hold off...
    anyone know if they are NLA??...as Audi keep saying it will there tomorrow..
  • T2Andy
    • 1903
    If its the small rubber hose that joins the 2 together ive just done mine having
    it exploded on me ,i used some reinforced hose of the same diameter ,TIP,fit to the banjo bolt first
    • s2avant
      • 2426
      Which bit of pipe do you need? Sorry I'm being thick but I'm knackered. If it is the bit that Andy mentions above your stealer is probably messing you about as it comes on a 5m roll and you only need 73mm. They will probably want you buy all 5m. I can order it but I would have to charge you for 1m (although I guess the warehouse wouldn't notice 73mm missing off the end of the roll )
      Give me a call in the morning (or drop me an email) if you like and I'll look into it for you.
      Ben
      • europeanme
        • Oct 2005
        • 3817
        my banjo bolt is pretty much dead!!...it's had coolant leaking all over it...and some previous joker has rounded it off... so need one of them also....
        • europeanme
          • Oct 2005
          • 3817
          Originally posted by s2avant
          Which bit of ipie do you need? Sorry I'm being thick but I'm knackered. Give me a call in the morning (or drop me an email) if you like and I'll look into it for you.
          Ben
          Cheers Ben,
          I'll mail you..ready for the morning....
          Mike
          • europeanme
            • Oct 2005
            • 3817
            sorted!!!...it had arrived....
            Thanks for the help chaps.....
            • PistonBroke
              • Dec 2008
              • 118
              Any of you guys got a spare 73mm of either the reinforced hose or the proper OEM one. I got a piece of hose to do this but I'm wondering if it might not be up to the job. I think it is fairly ordinary heater hose but it does have thin cords inside the walls - do you reckon that is reinforced or are all water hoses like that.
                Originally posted by europeanme
                Having narrowly avoided blowing my turbo up as the above hose was hanging on by a thread. It is proving not the easiest item to get hold off...anyone know if they are NLA??...as Audi keep saying it will there tomorrow..
                Here is a partial parts list. Note 25 and 26.
