steering arm (s) wanted
  • andyg plym
    • Nov 2006
    • 4646
    anyone have any spare? my track rod ends are seized solid
    are they the same as coupes etc?
  • s2_bo
    • Oct 2005
    • 6067
    Yeah they are all the same. Not easy to replace though mate.
    Maybe also get new iner bushes from bambridge and new adjuster rods.
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • andyg plym
      • Nov 2006
      • 4646
      i take it its crap access to undo them? is it 2 bolts on the rack?
      • AndyP
        • 6049
        It's a lot easier on an ABY than a 3B, and yes, the 2 bolts on the end of the rack.
          I've got a spare passenger side one, needs a bush though as i removed it when i drew up the delrin ones for Kev... you'd need some of his delrins ones to use it but i've no use for it
          • andyg plym
            • Nov 2006
            • 4646
            cheers alex my s***** mate but ideally i need a drivers side one. i hit a kerb in the snow and bent the wishbone, which i replaced but now my wheels need tracking badly and my rod ends are not good
              get a couple new ball joints and some of the 17mm hex ones off Kev. Blow torch and stilsons should get the old ones off but will destroy the adjusters and likely the ball joints in the process though
              • andyg plym
                • Nov 2006
                • 4646
                how hard would it be to get the arm off the rack? reckon i stand a better chance if its off the car
                  not too bad, its easiest to remove both rods by unbolting the yolk thing from the rack and pulling the whole lot out through the inner wing
                  • andyg plym
                    • Nov 2006
                    • 4646
                    dont like the sound of that! Just looked at some old posts and it seems peeps have had real probs with yokes seizing etc. is there just no way to get to the bolts on the rack in situ?
                      yeah its no problem, just more fiddly
                      • andyg plym
                        • Nov 2006
                        • 4646
                        so just 2 bolts and off it comes? dont tell me allan key bolts that will be seized solid
                          2 x M10 nuts to undo, the you have to push the stud plate backwards to free the studs from the yolk, and then slide sideways without damaging the rack boot. If you are unlucky the captive studs with become... err.. less captive than they should be... then it becomes a PITA and you will need to take you yolk off anyway
                          • andyg plym
                            • Nov 2006
                            • 4646
                            cheers alex il give it a go! must be easier to undo when put in a vice with some heat:mischeif:
                            • s2_bo
                              • Oct 2005
                              • 6067
                              Ahh yeah. I forgot you had an aby! .
                              If you have a vice you could grip the bush ends and heat the adjuster rod ends which should help free them up.
                              Use loads of copperslip when fitting the new adjuster rods.
                              Its defontaly worth replacing the track rod ends too as that blow to the wheel has most likely killed it and I bet they won't come off with out a balljoint splitter so they are as good as dead anyway.
                              So if I where you I would reuse the old arms if they are not bent, buy and fit:
                              New inner bushes
                              New addjuster rods
                              New track rod ends
                              New ball joints
                              Then get the 4wheel alignment done.
                              91 S2 coupé - RIP
