Wanted - RS4 Gearbox Spacer plate
  • Wanted - RS4 Gearbox Spacer plate
    part No. 01X 103 551
    or even if i could borrow one
    PM me if anyone can help....
    Brian
    Audi Nut!!!
    Brian, this is not the same as the rs2 one is it?
      Seems to be on many cars
      http://www.vagcat.com/epc/find/?art=01X+103+551
      Audi A6 allroad quattro 2000 , 4B. OIL SUMP, SEALING FLANGE, NO REPLACEMENT PART 4.2ltr.
      221KW 8 cylinder:
      BAS
      Audi A6 allroad quattro 2001 , 4B. OIL SUMP, SEALING FLANGE, NO REPLACEMENT PART 4.2ltr.
      221KW 8 cylinder:
      BAS
      Audi A6 allroad quattro 2002 , 4B. OIL SUMP, SEALING FLANGE, NO REPLACEMENT PART 4.2ltr.
      221KW 8 cylinder:
      BAS
      Audi A6 allroad quattro 2003 , 4B. OIL SUMP, SEALING FLANGE, NO REPLACEMENT PART 4.2ltr.
      221KW 8 cylinder:
      BAS
      Audi A6 allroad quattro 2004 , 4B. OIL SUMP, SEALING FLANGE, NO REPLACEMENT PART 4.2ltr.
      221KW 8 cylinder:
      BAS
      Audi A6 allroad quattro 2005 , 4B. OIL SUMP, SEALING FLANGE, NO REPLACEMENT PART 4.2ltr.
      221KW 8 cylinder:
      BAS
      Audi A4/Avant 2001 , 8E-1-000 001 >> , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Audi A4/Avant 2002 , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Audi A4/Avant 2003 , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Audi A4/Avant 2004 , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Audi A4/Avant 2005 , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Audi A4/S4/Avant quattro 2001 , 8E-1-000 001 >> , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Audi A4/S4/Avant quattro 2002 , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Audi A4/S4/Avant quattro 2003 , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Audi A4/S4/Avant quattro 2004 , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Audi A4/S4/Avant quattro 2005 , 8E. CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9ltr.
      4 cylinder:
      diesel eng.:
      AWX,AVF
      Passat/Santana 2003 , 3B3, 3B6 CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9/2.0ltr. diesel eng.
      Passat/Santana 2004 , 3B3, 3B6 CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9/2.0ltr. diesel eng.
      Passat/Santana 2005 , 3B3, 3B6 CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9/2.0ltr. diesel eng.
      Passat syncro/4Motion 2003 , 3B3, 3B6 CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9/2.0ltr. diesel eng.
      Passat syncro/4Motion 2004 , 3B3, 3B6 CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9/2.0ltr. diesel eng.
      Passat syncro/4Motion 2005 , 3B3, 3B6 CYLINDER BLOCK WITH PISTONS, OIL SUMP 1.9/2.0ltr. diesel eng.
      Audi A6/Avant 2005 , 4F-5-000 001 >> , 4F2 CYLINDER BLOCK WITH PISTONS 2.4ltr.
      130KW 6 cylinder:
      BDW
      Audi A6/S6/Avant quattro 2005 , 4F-5-000 001 >> , 4F2 CYLINDER BLOCK WITH PISTONS 2.4ltr.
      130KW 6 cylinder:
      BDW
      Audi A6/Avant 2005 , 4F-5-000 001 >> , 4F2 OIL SUMP, SEALING FLANGE 3.0ltr.
      160KW 6 cylinder:
      BBJ
      Audi A6/S6/Avant quattro 2005 , 4F-5-000 001 >> , 4F2 OIL SUMP, SEALING FLANGE 3.0ltr.
      160KW 6 cylinder:
      BBJ
      Audi A6/Avant 2005 , 4F-5-000 001 >> , 4F2 CYLINDER BLOCK WITH PISTONS, OIL SUMP 3.2 l
      188KW 6 cylinder:
      AUK
      Audi A6/S6/Avant quattro 2005 , 4F-5-000 001 >> , 4F2 CYLINDER BLOCK WITH PISTONS, OIL SUMP 3.2 l
      188KW 6 cylinder:
      AUK
      Audi A6/Avant 2005 , 4F-5-000 001 >> , 4F2 CYLINDER BLOCK WITH PISTONS, OIL SUMP 3.0ltr.
      155/165KW
      6 cylinder:
      diesel eng.:
      BMK,BNG
      Audi A6/S6/Avant quattro 2005 , 4F-5-000 001 >> , 4F2 CYLINDER BLOCK WITH PISTONS, OIL SUMP 3.0ltr.
      155/165KW
      6 cylinder:
      diesel eng.:
      BMK,BNG
        Epic thanks for that I did not think of searching to see if it fits anything else.
        I dont think the RS2 one will fit as the RS4 flywheel is larger.
        Once I get the correct item I need to speak nice to Bambridge to machine me one 15mm thick, I have mocked up the rs4 engine onto a coupe quattro(typ85) gearbox tonight and successfully managed to get the clutch to function correctly at this Spacing
        I will be using the original RS4 flywheel and pressure plate, I just need to find a slightly larger diameter friction plate than a UR one with the correct splines in the centre.
        The rs4 starter bolts up into position and I have had it turning over on the starter
        Audi Nut!!!
          ah i see, cause i have my old rs2 one i could send you from greece,but looks like its not going to work.
            Good to see family life aint slowing you down Brian
              No Kev, still cracking on....
              I have sorted a spacer so when it lands can you have a look at making me a thicker one?
              pretty please.......
              Audi Nut!!!
                Back to wanted again guys, the one I have received is not for the B7 RS4 FSi engine so will not clear the flywheel....
                Has anybody got one please???
                Audi Nut!!!
                  did Grizz get back to you??....
                    iirc the bolt pattern is the same on a few engine varieties....V8, V6 and some diesels....
                    shall i ask if one can be "borrowed"?
