i will look back home if the part is the same for LHD/RHD. I have one which should be brand new. if it is the correct part, i can sell it for 100GBP+shipping
gift as paypal or bank transfer.
I think new is something in the region of 180GBP. Someone may confirm.
What material is that? All high pressure hoses I have read it used so far in the system tend to increase noises. Is be interested to know if there is a proper replacement!
sent using Android
The guy I'm referring to makes replacement hydraulic hoses for all types of industrial machinery. Similar to "Hose Doctor" in the UK. If the bore of the pipe is a match for the original part and the fittings are the same then it should work fine shouldn't it?
I had recently one made for.my power steering and it was noisy as hell. Fitted an oem and noise is completely gone. So I am not impressed with the usual braided equivalents to high pressure replacements. If this is something different, then id like to see the results!
sent using Android
Like for like replacement, I don't think anybody could handle the power losses that bigger machinery would have if the replacement stuff was all braided inside. I'll take some photos the next time I'm having a hose replaced for clarity.
Thank you for the offer, however given it's cost either new or even your one, I may ask Pirtek over here to make one up using the end connections from my old one.
no problem David. If you try and things dont work out, give me a shout, as mine is just sitting. I have no bomb anymore so its no use to me.
we can work something out in the end!
