Oil Return Hose with Air-Con for Turbo
  • ian4455
    • Nov 2010
    • 787
    Anyone got a Turbo Oil Return Hose for a 3b with Air-con (hose connects to block)
    Or correct part number ?
  • twenty valve
    • Oct 2010
    • 630
    this ones off an ABY with aircon which drains to the sump. Not sure if it's the same though
    • epic
      • 1317
      exta online
      12 034145735B oil pipe return / 3B
      (12) 034145735D oil pipe return / ABY
      (12) 034145735G oil pipe return / air condit.
      • ian4455
        • Nov 2010
        • 787
        Ok, can someone advise which oil return pipe can be fitted that returns oil to the side of the block ??
        • johne
          • Apr 2007
          • 1405
          The one for cars without air-con.
          John
          • ian4455
            • Nov 2010
            • 787
            Advise which part number,
            • johne
              • Apr 2007
              • 1405
              As above:
              034145735 B for 3B (not clear from ETKA if this is with or without A/C)
              034145735 D for ABY without A/C - looks like the one you want
              034145735 G for ABY with A/C
              John
              • brianb
                • Aug 2008
                • 248
                yes sir!
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Can any on confirm gasket part number to the engine block drain ?
                  Chef
                    OEM is 035145757C
                    Reinz p/n is 509200320
                    HTH mate
