UR / S2 rear driveshafts
  • Jeffer
    • 2057
    Looking for UR or S2 rear driveshafts. Please offer everything that could be of interest.
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
  • cooperquattro
    • Jan 2011
    • 815
    Which are you after??they are both very different to each other
    • Jeffer
      • 2057
      both the longer and the shorter one
      High Octane website
      • saltinot
        • May 2004
        • 1946
        FYI. The urq fronts are the same as the rear.....just swap sides left to right. You can also use rear driveshafts from a B2 90q, which are the same as urq front and rear.
        • quattrostyle
          • Oct 2006
          • 6229
          the rears of a CQ type 85 should do aswell then
          • JP
            • 1858
            Friend of mine has a whole rear rs2 setup diff and shafts if of any use?
            UrS6 Stroker + HTA3586 =
            • KubaLibre
              Banned
              • 1
              dutasteride generic
              generic dutasteride is used to treat Benign prostatic hyperplasia (BPH) also known as benign enlargement of the prostate (BEP).
              buy avodart australia This medicine helps to control your symptoms, diminish urinary retention and reduced your risk of needing the surgery.
