3B clutch pressure plate wanted
  • george21
    • Aug 2007
    • 226
    • Home: Lithuania Current: United Kingdom
    as above looking for 3b pressure plate for clutch.have to be new or very little used.
    i can't get it anywhere, not avialable from dealers anymore
    i'm fitting a ABY engine to my ur and keeping ur gearbox. so i'm using 3b flywheel machined to take aby crank and using ur friction plate. and i come to dead end. first of all you can't buy pressure plate and friction plate separete have to buy a kit. that will cost double as you use only halve of the kit pressure plate from 3B kit and friction plate from UR. i can live with that, but kit for 3B not avialable...
    so please help,
    or maybe other ideas what i can use for my setup??
    and there is my little rebuild
  • AndyP
    • 6049
    This place is still listing a new one
    I can't believe how hard it is to get a clutch for a 3B these days, neiter ESP or GSF are listing one now
    • george21
      • Aug 2007
      • 226
      it's pi....s me off!! i rang dealer today and i said if i bring my 3b s2 to change the clutch waht you going to do!!!! he had no answer... madness
      • george21
        • Aug 2007
        • 226
        another thing i'm after is all the plugs/ connections for coil conversion. i know a company in findland ot somwhere there selling them, but is avialable here in uk? anylink or directions? thank you guys for help!!
        • SteveH
          • 4460
          I have a Sachs pressure plate that was used on my motor for about 1000 miles. You can still see the machining marks on the pressure face. Drop me a PM if you're interested.
          Steve
          91 Modded 3B
          14 A6 Avant Black Edition
          • dunstan
            • Apr 2011
            • 103
            Ive just done a 3b into 80 quattro.
            Had no problems getting the clutch cover and even got a paddle clutch plate to fit.
            I do still have a spare 3B clutch cover,But ill keep it.
            The people who supplied the clutch are techniclutch,im sure they can get you a pressure plate no problem. The pressure plate cost me ÂŁ100 and the paddle friction plate was ÂŁ270 including delivery.
            They are in the UK,the website isnt very good,But I have to say I got good service from them.
            BTW I didnt have to machine the fly. You only have to put the spigot bearing in.
              try Brakes International they seem to be able get hold of stuff noone else can
              • george21
                • Aug 2007
                • 226
                Thank you for that mate, i'll give them a call 2morrow.
                Regarding 3b flywheel you have to machine out centre hole to take ABY crank, open it up to around 42mm
                I dont know how you fitted yours the hole it's way to small to to go on crank, maybe you use different flywheel or engine
                  the 3B flywheel should bolt straight on to the ABY crank
                  • Knight Rider S4
                    • 3541
                    If buying from techniclutch be sure to check everything , I had bought one for my S2 and was stated to be "performance" clutch kit and it last 5 miles and started slipping (RS2 setup) I used a company called Kestrel and they did excellent job !
                    93 S2 Avant Parting
                    91 URQ RR
                    02 A4 tdi Avant
                    • george21
                      • Aug 2007
                      • 226
                      Aby flywheel dual mass 3b single mass it won't fit without machining. hole is to small on 3b flywheel to take ur gearbox. Maybe it fits if you are using 6 speed box.
                      • jsws3
                        • Apr 2012
                        • 1174
                        Why not put a 6 speed in your ur ?
                        And any pics of your car for all to enjoy ?
                          ahha now it makes sense, its an 016 box right?
                          • george21
                            • Aug 2007
                            • 226
                            For 6 speed gearbox on ur you have to widened the tunnel.
                            And yes it's a 016 box
                            • jsws3
                              • Apr 2012
                              • 1174
                              As far as I'm aware you don't need to widen the tunnel and white cottage Quattro has done lots of them and Quattro Coachwork has done 4 that I know of .
                              And mine Is under way as we speak .
