Ribbed hose
  • bilko0795
    • Feb 2011
    • 1883
    Ribbed hose
    Anybody have a spare ribbed rubber hose its the one that goes from the throttle body to the lge intake pipe. Mines split. Pm me with details plse.
    thanks.
  • Christophski
    • 3632
    Aby or 3b bud? I have the Aby set somewhere both boost and water hoses if it helps? I'm never using them again.
    • driftin jo
      • Sep 2007
      • 2222
      i would say 3B as there is no ribbed hose on an ABY
      • Christophski
        • 3632
        Fair enough
        • here2learn
          • Feb 2012
          • 325
          mine had split and i priced up a silicone reducer and a 90 with a bit of stainless pipe to weld the little outlets for the other pipes and came in at about £28 which also allows you to change the placement of the filter.
          • bilko0795
            • Feb 2011
            • 1883
            Mines Aby
            • Christophski
              • 3632
              In that case I can help. No idea how much they are... Offer then I will look at postage cost too if you like?
              • bilko0795
                • Feb 2011
                • 1883
                http://i1180.photobucket.com/albums/...g?t=1352715292 Here is the hose that i require apologies for any confusion.
                • Christophski
                  • 3632
                  Im fairly sure I have that one in a box with the others. Let me know an offer and I will go and check for it and if I do then sure we can sort somethign out. Will have to be after work though bud if thats ok?
