Turbo Hose For RR
  • steverrquattro
    • Oct 2006
    • 787
    Turbo Hose For RR
    I need the turbo hose for a UR RR20V. I've had a look on VAGCAT and it has no part number listed so I can't compare to see if it's the same as a 3B, ABY or ADU.
    Either way, I need the turbo hose as the one I have is split around the WGF (N75) valve.
    Advice on if it's the same is welcome + let me know if you have one in perfect condition.
    Cheers.
    Steve
    1990 RR 20V
    1982 SWB UR - RS2 Engine
  • spink
    • 4382
    I think i have 1 or 2 that came off RRs,quite possibly same as a 3b.can look tomorrow if you dont get sorted
    • europeanme
      • Oct 2005
      • 3817
      Cheers.
      off topic, did you speak to Lance about exhausts?
        You might want to check VAGCAT under AQS, MG1, SG45, Ill. 20-05 and 20-15.
        The MAF to turbo hose is 034133357Q and it is unique to the RR.
        The turbo outlet to intercooler inlet hose is 034145746L and it too is unique to the RR.
        Hope that helps a bit.
        • AndyP
          • 6049
          RR - 034 133 357 Q
          3B - 034 133 357 AB
          ABY - 034 133 357 AA
          I'm 99% certain that a 3B will fit.
          • europeanme
            • Oct 2005
            • 3817
            Cheers.
            why not get Roose motorsport to make you one up if you have the old one....
            • Blauer Donner
              • Jul 2007
              • 44
              Hello,
              no the 3B MAF Hose is longer, will not fit!
              We have a silicone item exact for the Urquattro RR!
              It is a replace part and will fit 100%
              More info please send PM
              Gerd GTM
              kind regards
              • quattrostyle
                • Oct 2006
                • 6229
                I had GTM hoses on my S2 coupe, they were fine although thinner than Roose hoses.
                • Blauer Donner
                  • Jul 2007
                  • 44
                  Our Hoses have are improved now, all have 5ply and 6mm wall.
                  The inlet Hose (MAF) is really strong now!
                  best regards
                  Gerd GTM
                  kind regards
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    best regards
                    Gerd GTM
                    bit off-topic
                    do you do 92.8 stroke crankshafts for our 5l engines true?
                    • Blauer Donner
                      • Jul 2007
                      • 44
                      yes but please send PM or email
                      service@gt-motorsport.net
                      best regards
                      Gerd GTM
                      kind regards
                      • steverrquattro
                        • Oct 2006
                        • 787
                        Sorted and thanks.
                        PS I'll have a look at Rouse Motorport and GT Motorsport for hoses on my ADU engine to see waht they do.
                        Steve
                        1990 RR 20V
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          best regards
                          Gerd GTM
                          dont worry,it was only to verify it...because i believe to saw in Ebay.de those crankshafts in the past...from a company called GTM. so is yours
                          is nice to know because sometimes here there are some people asking for those stroke crankshafts to build new stroker engines...probably with short blocks
                          thanks mate
                          • quattrostyle
                            • Oct 2006
                            • 6229
                            best regards
                            Gerd GTM
                            Good to hear Gerd! Will get in contact if I'm in need of new hoses.
                            My old S2 is driving around for 3 years now with your hoses.
