PS Pump WTD
  • RustyNut
    • 1433
    • Home: Zambia Current: United Kingdom
    PS Pump WTD
    Hi All,
    I've re-built my existing PS pump but it now leaks worse than it did before the re-build... I'm after a decent one that doesn't leak to replace mine whilst I investigate what we did wrong.
    Needs to be recession priced as i've already wasted a lot trying to make mine good .
    Russ
    Old Stuff Reborn.
    It needs to be ABY or ADU item.
    • cooperquattro
      • Jan 2011
      • 815
      i have a excellent aan one if its the same??
      • jade
        • Jan 2005
        • 1811
        • Home: New Zealand Current: Spain
        Originally posted by RustyNut
        Hi All,
        Russ
        I have rebuilt 2 no leaks, unforturnately one it still rattles a bit
        you need to replace the 2 x screws with new ones not just changing the o rings
        RS 2 580HP
        • RustyNut
          • 1433
          Cheers Andy, forgot to say it needs to be ABY OR ADU, pretty sure AAN isn't compatible (cheers for the offer). I'll look in to what the issue was when I remove it.
          Old Stuff Reborn.
