ABY valve cover
    ABY valve cover
    As above wanted please.
    Don't need the coil cover if that makes a difference
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    Hy! I have an AAN one iff this helps.
    Regards!
    • rj scotty
      • May 2006
      • 2195
      Ill swop you mine for your 7a
      BUT I DON'T WANT A NEW CAR!
      1995 S2 Avant, Volcano Black
        Alex, when you do get this, can you have a look at the breather and post a few pictures up please. I'm interested in adding a 19mm breather to mine in a similar to stock position but with a better designed pipe on the inside and would like to see some pictures first.
          I have an AAN one here if that will help Andy? The only reason I wanted an ABY was the angle of the breather hose is a PITA.
          Rich - I would swap but I still need my 7A one for the time being as I'm trying to build up my engine and do the swap in one hit so not too much downtime on the car.
            I have an ABY one
              do us a deal then big boy
                Which hose? The breather connection to the inlet? That's easily removed
                If they're identical and you don't want the AAN one, then I may be interested for some investigations into it a new head breather setup.
                  Yes the outlet of the breather pipe that runs through the cover - the ABY/ADU one is shaped differently to avoid the intake pipe.
                  how do you remove that mate? Just pull it out? I didn't want to damage it as I guessed it was pressed in
                    Yeah, the ABY one just pulls out so see no reason why the AAN one doesn't... (famous last words)
                    AAN - 034 103 724 B
                    ABY - 034 103 724 F
                    Gaskets are the same
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      http://www.ebay.co.uk/itm/Audi-S2-ro...item257a8b9c60
                        Cheers for that, some good pictures there.
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          Not mine by the way just found it while looking for something else
                            I have an AAN one here if that will help Andy? The only reason I wanted an ABY was the angle of the breather hose is a PITA....
                            And it is not just the difference between the angle of the ABY PCV system exit tube, it is the other little multi-angle tube and rubber connector that is involved with the ABY. AAN is much more straight forward (pun intended):
                            ABY:
                            • pixsaudisex2
                              • Sep 2004
                              • 3110
                              They both pull out Alex pulled one off a few times ,
