Radiator fan motor for 3b
  • Monkeymagic
    • Mar 2012
    • 3419
    I have been looking and the oe part number is 165 959 455AE.
    They cross over with a diesel mk2 golf item the spec being 250/350w and 305 mm diameter fan. I can find them from febi cheap enough but it has a different wiring connector meaning I'll have to adjust the loom.
    Has anyone got one save me having to replace the loom connector. Not a huge issue but I'd rather not. Many thanks Steven.
  • s2driveruk
    • 12696
    I searched for ages then decided to go with a high draw Pacet unit which is good for general usage but you may want something even bigger pull wise for track driving in my opinion.
    The OEM was NLA when I delved into sourcing one. If it is just a connector block change then shouldn't be too much of an issue tbh
    1992 3b S2 Coupe
    • goodazz
      • Jan 2008
      • 417
      • Country: Lithuania
      hello i think i may have the fan.
      will check it tomorrow.
      p.s.: have you received the spoiler lip?
        • 4754
        I have a fan motor in perfect working order gen 68k low mileage of a Nov 1991 20V 7A part number 893 959 455.This is the slightly older part number where the 893was B3 chassis then number changed for the B4 shape. In this case the bosch part number might be of use 0130109229 because of the changes to audi part numbers for the same item.
        Anyway if this is any good to you it's £45 delivered.Pm if interested.Cheers.
          I might have one Steve, can't remember if i threw it out (typically noone needed it for months while I continually bashed my shins on it working in the garage)
          If i still have it, you can have it for free. I'll check later
            Hella p/n is 8EW 009 144-411 for a new one BTW hope that helps
            • Monkeymagic
              • Mar 2012
              • 3419
              Goodazz yes bud thank you. It's a shame I don't have a car for it though- that's another story.
              VDT I think that plug is different. I'll check later but yes if it's the same it's a deal.
              Alex if you have one I'll take it for stock- paid of course. Cheers all. Steven
              • Monkeymagic
                • Mar 2012
                • 3419
                VDT according to etka the 7a fan was 323959455a this is a two stage 250/150 watt, so it's the wrong wattage I believe.
                Part number 893 959 455 crosses over to 443 959 455k but I can't find the wattage etc.
                  • 4754
                  My part number is definitely 893 959 455.Was the Bosch part number of no help? Sorry i can't be of any more help as i have no idea about wattage ect.I just thought it was worth a try for you.It's here for a while should you require it before it goes on ebay at some point.Let's hope some else sorts the exact one out for you
                  • Monkeymagic
                    • Mar 2012
                    • 3419
                    It's a different bosch number to mine mate. I assume there is some difference I may be wrong. I'll get onto my mate in the vw parts dept in morn. Many thanks for the offer.
                    • Monkeymagic
                      • Mar 2012
                      • 3419
                      Got one direct from febi part number 06992. I'll have change the plug but that's no hassle
                      works out about 75 quid for all the bits brand new.
                        • 4754
                        Good news then!! Was it a Febi or Gen Audi part?
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          Obsolete with vag and tps. Obsolete with Bosch.
                          vw heritage wanted 360 quid. So got hold of febi who said yes we got one we will send it tomorrow.
                          I use Andrew page for febi bits lots and no complaints so far.
                            • 4754
                            Wow,never ceases to amaze me the silly prices Audi come up with.£360 but NLA I think i better hold onto mine in case i need it especially the vintage of it when bosch really meant something and made top quality!
                            • Monkeymagic
                              • Mar 2012
                              • 3419
                              If it were available from vag it's 300 ish heritage have put a further mark up on it.
                              then traders like veedubmachine Do pattern parts for 45 and febi do it for 70. It goes to show the profit!
                              anyway my fan and breather pipes should arrive in tomorrow.
                              these cars just love to keep you on your toes.
