AAN Crank Locking Tool
  • andy10v
    • 5996
    Originally posted by geneandbolly
    andy, i'm not sure i'm getting your street chat here.. when i floor it, there is one big backfire when the throttle is pushed to the floor. it never does it if i take the acceleration gradually up and over the 4000rpm mark, only when i plant the boot. i guess i'll have to get it into the garage and have them check it. i'm going to go ahead and get the cambelt etc done on it so might as well get the misfire seen to as well. at least that will save me farting around with leads when it might be something simpler.
    many thanks.
    sorry
    WOT-wide open throttle
    POS also stands for piece of **** (as the only time you have anything to do with the power output stage is when its acting up )
    From SJM, good info on missfires under load, POS description etc
    450nm for crank pulley with Audi tools, often done as 200nm+180degrees as a DIY alternative. You will need a big torque wrench (norbar 5r style), or a big breaker bar/scaffold tube)
    Crank pulley is about £30 from audi, or about £100 for an after market billet one, its bolted to the back of the harmonic damper/accessory drive, pictures from when I changed mine;
    Old pulley being removed
    New billet one
    Sold ABY-stock
    • geneandbolly
      • Sep 2013
      • 1356
      Originally posted by Rikki Kitto
      If ya need new POS units mine will be for sale soon as I'm doing the coil conversion
      i could well be interested - please keep me posted . .
      1997 Audi S6 - The Purple Helmet!
      • geneandbolly
        • Sep 2013
        • 1356
        thanks for that information, andy - i'll pretend that i understand even half of it!!
        • geneandbolly
          • Sep 2013
          • 1356
          can anyone tell me if this tool will work with the aan engine?
          http://www.ebay.de/itm/VAG-2084-AUDI...item43cc32f210
          or will i have to take the plunge and buy this one instead?
          http://www.ebay.co.uk/itm/3810181960...%3AMEBIDX%3AIT
          alternatively, can anyone out there please lend me this tool?
          i'd be happy to pay the postage both ways.
          thanks,
          craig
            #20
            You need the 3256 tool for AAN. I am looking to buy such a tool as well soon. Borrowed one before but is nicer to have thine own.
            • geneandbolly
              • Sep 2013
              • 1356
              thanks for that info.
              almost done collecting bits for the job. the multifunction temp switch and the two short thermostat and turbo hoses are coming next week. crank locking tool aside, then the job's good to go . .
