Bilstein Bump Stops (front)
  • rotoryboy
    • May 2004
    • 3281
    Does anyone have or know where to get them from??
    Thanks in advance
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
  • s2driveruk
    • 12696
    i'm not sure any exist,I dont currently have them on my Bilsteins and the only way to make some is to use the existing OEM bumpstops and make the shaft hole larger to accept the bigger shock
    1992 3b S2 Coupe
    • PeterS
      • 423
      Guys:
      You dont need them, due to the design of the bilstein front struts....
      -Peter
      Peter S
      1990 ErsatzS2 - track toy
      1991 Coupe Quattro
      1991 Coupe Quattro
      1995 S6 Sedan
      1995 S6 Wagon
      • The Spanish
        • Nov 2003
        • 719
        What!!!
        Do OEM Blue top mounts don't fit with Bilsteins?
        I have heard that at QRSport do have some rose joint top mounts that somebody fitted with bilstein.
        If you find more info please share as I will need the same as you.
        What about the rear?
        94' RS2 Coupe TT (Twin Torsen )
        • PeterS
          • 423
          Gents:
          I think that we are confusing the external bump stops that are on the strut shaft ( foam or poly) with the topmounts /strut bearings.
          Due to their design, the fron bilstein strut cartridges DO NOT require external bump stops.
          HTH
          -Peter
          Peter S
          1991 Coupe Quattro
          1991 Coupe Quattro
          1995 S6 Sedan
          1995 S6 Wagon
          • Stick Insect
            • Dec 2003
            • 2338
            The bump stop is different from the top mount. so Don't worry.
            David
            • s2driveruk
              • 12696
              Yeah exactly, the blue top mounts are fine with them but the bumpstops are either not available or you will need to try and modify an OEM one.
              David
              1992 3b S2 Coupe
              • The Spanish
                • Nov 2003
                • 719
                Understood
                • s2driveruk
                  • 12696
                  p.s. If you want to try modifying some OEM ones I have 4 new ones still in packaging from when I bought my Bilsteins but when i realised they didnt fit I didnt get around to making them bigger so if you have the time and want to try Pm me and we can sort out a (cheap) price for them
                  David
                  1992 3b S2 Coupe
                  • rotoryboy
                    • May 2004
                    • 3281
                    Thanks matey but they are on the car now without any bump stops, will see how it goes. May take you up on the offer if it bottoms out
                    Mark
                    Race Clio RS197
                    • s2driveruk
                      • 12696
                      mine havent yet so you should be fine
                      1992 3b S2 Coupe
