aby oil squirters
  • S3ilver
    • Mar 2014
    • 102
    aby oil squirters
    Looking for a set of ABY oil squirters.
    ta
  • sailaz
    • Oct 2009
    • 647
    • Country: United Nations
    035103157B is found not only in ABY engine: http://www.s2forum.com/forum/showthr...836#post935836
    • quattrodave
      • Dec 2008
      • 218
      ta
      I'm sure I have a spare set off a 7A block which are the same as the 3B and ABY ones (it was leftover when I rebuilt my engine into another block), can't check until Friday as all the parts are in my parents store garage. If nothing turns up in the meantime I'll let you know at the weekend if they are available.
      • S3ilver
        • Mar 2014
        • 102
        Sorted now thanks
        • diesel des
          • 3896
          I would be interested in a set if anyone has some? Cheers des
          • quattrodave
            • Dec 2008
            • 218
            OK will check if I have the set mentioned when I go over to my parents today (its mothers day)
            • diesel des
              • 3896
              Good man cheers
              • diesel des
                • 3896
                Did you have any luck locating these? Cheers
                • quattrodave
                  • Dec 2008
                  • 218
                  oops forgot to look, back over on Friday so will check then !
                  • diesel des
                    • 3896
                    Good man thanks!
