I need a broken 3B or 7A distributor
  • stragenmitsuko
    • Apr 2004
    • 28
    I'm trying to obtain a 3B distributor with a broken plastic gear .
    Maybe someone has one lying around .
    The goal is to take it apart and try and machine an oil seal in it .
    I 'd rather try this on a broken one , then to destroy my good
    dizzy .
    Results will offcourse be posted on the forum .
    P.carlier -at- pandora.be
    Thx
    Patrick
  • WabTheKing
    • May 2004
    • 2567
    what do you mean "machine an oil seal in it"?
    • stragenmitsuko
      • Apr 2004
      • 28
      Right now there's no oil seal in the distributor .
      I'm gonna take one apart , put it in a lathe , and
      cut a groove to put a small shaft seal in it .
      That ought to keep the oil from entering the dizzy cap .
      Pat
      • porkkis
        • 1994
        Correct. There is only a "felt" type seal that won't last forever.
        Good idea.
        • PeteRR
          • 1326
          Check your breather system if oil's getting in the dizzy!
          • PeterS
            • 423
            Exactly...If your distributor is leaking oil then you have an issue with the crank breather system. Look there first.
            Peter S
            1990 ErsatzS2 - track toy
            1991 Coupe Quattro
            1991 Coupe Quattro
            1995 S6 Sedan
            1995 S6 Wagon
            • stragenmitsuko
              • Apr 2004
              • 28
              Yes I know about the crank breather system .
              It's been compleately renewed and cleaned .
              But still , I think it's a nice thing to try .
              If only I could find that -garbage bin - dizzy .
              Pat
