you have not familiar for the gems device? And for defense of aftermarket ecu's the "safety maps" are called correction maps, or egual, there is no need to have huge 3d safety map for limping home, if some tempereature is too high -> add x% fuel, if some cyl is hotter then other, you can add 2% correction to it so you can get even engine, not the way that motronic, waits untill something goes wrong and then correct the problem (well, you got your forehead agaist windshield
limpmode.
well I didnt meen to have every car included, just aby/aan, and for 3b dudes, make a conversion to directfire.
It is actually very simple peace of electronics, replacing eeprom to eeeprom aka flash and have com port to the flash programmin pins.
Rest is software, and thats is easy, ready made software is available and this kind of simple programmin should be weekends job for wizards like mihnea.
And if the big secrets, map locations and correspondigs are not to be make public, there is several methods of scrambling the data and use matching base for the eeprom.
Any one making this happen, it is Very good money, in our little country of Finland, I believe there would be ta least 10 people in the instant to pay 1000e for self programmable motronic, more than that has gone for aftermarket ecu all ready. imagine the market for uk, germany and active US community. And for knock sensing and safety maps, they would all be there.
limpmode. well I didnt meen to have every car included, just aby/aan, and for 3b dudes, make a conversion to directfire.
