Fuel consumption - there is no need for PWM, simply run a 0-5V signal equal to IDC through a DAC.
Fuel consumption signal for dash
Tags: None
How do I do that with VEMS or MaxxEcu? Is the DAC external? If so do you have a link to one ?
I am working on making a config in MTune for the AAN Automatic.
Have not figured out how to send a 0-5v signal. Only PWM or on/off so far.Attached Files'96 UrS6 auto PRJ chipped E85
'95 80Q AEB VEMS E85 -
If I can configure a table with DC based on injector PW, it should work, right?'96 UrS6 auto PRJ chipped E85
'95 80Q AEB VEMS E85Comment
Something like this, right?
Output DC is equal to Injector DC at all rpm. Only thing TBD is frequency. Maxxecu pwm1 out Duty Cylce.jpg'96 UrS6 auto PRJ chipped E85
