I am considering remapping my RS2 can anyone suggest someone who is knowledgable about carrying out the work
Who should I use to remap my RS2
If you are using OEM hardware the best & cheapest way to go would be to get hold of a generic RS2 chipset or a chipped ECU from a reputable tuner - PRJ, Paul’s Homefries, MTM, PK-M, MRC. Sure there are others I have missed.Panthero Coupé quattro 20vt
Given the age of these cars and the potential variables you could end up dealing with, my advise would be to find someone that can do a custom map on a dyno. That is my next move once I am geographically in the right area! Do you plan on doing any other mods?
A lot of the period ECU upgrades disabled the ECU diagnostic capability to protect the “tuners” software.
We have frantically been buying Ur Quattro and S2 ECUs in standard spec because-
a) the modified units are compromised/tampered with (circuit board tampered with from OEM ) It seriously does make a difference on ECUs of this age.
b) they (some/MTM) delete diagnostic port access to protect source code
c) On MAC01 FA mixture ratio “free for all” can pre-ignite
d) On S2 Nothelle and MTM ECU units the overboost adds wear (don’t get me wrong, the engine can, if in fine health, cope with this).
e) A well sorted OEM RS2 sans modifications will always be the holy grail.
just my opinion. Apologies.Last edited by Ian Simmonds; 5 May 2019, 23:31.85 WR Urquattro, 85 20vT International liveried RallyRep
93 MTMS2 Avant
As above, there are reputable tuners, very few if any still cater for these old machines - buying their existing software (chips) would be the safest, cheapest & best outcome. You don't need the hassle and expense of a custom tune if you are using standard components as these pros have already done the hard work.
For my money I would buy a PRJ chipset and make sure the mechanicals are in top order and replace every sensor on the engine as well as the engine harness for long term reliability.Panthero Coupé quattro 20vt
- 1 like
