Maxxecu famous trigger problems.
  • mllen89
    • Apr 2015
    • 63
    Hey.
    i have the famous trigger problems, with maxxecu
    I've tried adjusting the volts and it worked. but still not perfect when I get above 5000rpm.
    my trigger voltage max is fixed at 10.5v, I think thats high.
    Is there someone who can confirm it too high?
    Or you can send a log file
  • amarider
    • May 2015
    • 41
    • Country: South Africa
    Don't want to state the obvious but please make sure your harness is plugged in properly! This had us struggling for a long time. You'd be surprised how many sensors work with it slightly unplugged. In desperation we even rolled back the software and that allowed the engine to start with the improperly seated plug. You can imagine how this can mess up any troubleshooting. Hope this helps someone.
    • S2_avant 19930325
      • Mar 2019
      • 648
      Originally posted by mllen89
      Hey.
      is the problem solved ?
      • S2ABYGTX
        • Dec 2015
        • 63
        • Country: Spain
        Hi, I had the same problem, I could configure it to not cut at 6500 but when it went below 4000rpm I suffered a lot of signal losses, it was impossible to drive it, finally I installed the 60-2 digital trigger and the problems are solved.
