Hi All,
I've a hard time figuring out the wiring on the primary and secondary triggers in the Ecumaster Classic.
For the primary trigger it seems straitforward connecting via PIN# 7 on the stock reference VR sensor. But for the secondary , I have no clue....
The engine (WR 5 cylinder turbo) has the 135 tooth flywheel VR sensor as well as the 1 window Hall distributor.
I don't know which to use (I would prefer the 2nd VR sensor for engine bay cleaness) and most importantly how do I connect it , which ECU pin ?
I sure hope you guys can help me with that , I've scroll dow the forum with no luck expect that that some of you are running the same setup.
thanks for any help
thanks for any help
