ECU Master (EMU black)
  • 20vTurbo
    • May 2004
    • 233
    • Home: England Current: Australia
    Greetings...
    Is there anyone on the forum running the EMU Black on a 'standard' S2, and by standard, I mean using the factory trigger/cam sensors?
    I've just moved away from the Autronic SM4 to the EMU Black... the Autronic used a trigger mode based on the factory sensors/triggers (as far as I'm aware) - this all worked fine, and I haven't changed any of this.
    I have everything wired up, but can't get the engine to fire. I'd just like to validate the trigger setup I'm using.
    The ECU Master software has the specific option 'Audi trigger' available for the primary trigger, secondary trigger and CAM#2 sensor. I've also followed an ECU Master article documenting this trigger setup... or at least as far as I can... it looks like it was written for an old firmware version, and the new firmware has more options to choose from... so I can't confirm all of these settings.
    When cranking the software is reporting cam sync is achieved, and the injectors fire, and it sound likes it almost abut to start, but doesn't quite get there.
    Can anyone help?
    Mick
    '94 S2 (RS2+ spec. Tarmac Rally Car)
    S2QuattroMotorsport
  • le mans
    • Nov 2013
    • 165
    • Country: New Zealand
    I wonder if it’s just not getting enough fuel to start? The fuel map might need tweaking to get it starting and idling. Are your fuel injectors correctly set up in the software?
    • 20vTurbo
      • May 2004
      • 233
      Thanks, I did check the fuelling, but all seemed to be OK. However, I have got it starting now... it was an issue with the the settings for the second cam sensor.
      S2QuattroMotorsport
      • SSPRL
        • Aug 2020
        • 18
        • Country: Ukraine
        Hey. I use emu black and can sent you some settings. You adjusted the trigger angle with a stroboscope?
        • add
          • Jan 2008
          • 931
          I had the same issue with EMU classic,had to change cam signal from rising to falling
          It's a love/hate relationship with the S2,i love it,it hates me
          • 20vTurbo
            • May 2004
            • 233
            Cool, that'd be great if you could please!... be good to compare.
            I've not got a timing gun, so haven't been able to confirm the timing is correct so far.
            My trigger setup is attached.
            This gallery has 1 photos.
            S2QuattroMotorsport
            • 20vTurbo
              • May 2004
              • 233
              See previous post showing my trigger setup...
              Primary Trigger is set to Falling
              Secondary Trigger set to Rising
              CAM# is set to Falling
              I referenced the attached guide found through the ECU Master website.
              S2QuattroMotorsport
              • Jaswan
                • Apr 2011
                • 774
                Does it start ok now?
                • 20vTurbo
                  • May 2004
                  • 233
                  Yep, all good now.
                  S2QuattroMotorsport
                  • Yuriah
                    • Apr 2022
                    • 2
                    I am currently trying to get my emu black to run and cannot for the life of me get my secondary trigger to read. I confirmed that my cam window and crank are timed correctly. I also confirmed that my sensor is good. Where would you guys go from here?
                    I was told to ground secondary triggers signal wire to see if it shows on my logs and it didn't. I think my wiring needs to be looked at. Anyways, nice to see other guys running this ecu!
                    • 20vTurbo
                      • May 2004
                      • 233
                      Here's my current working trigger setup... EMU Client Version 2.140
                      S2QuattroMotorsport
                      • Adrian122
                        • Mar 2025
                        • 1
                        • Country: Slovakia
                        hello I am using EMU black on my Audi AAN and I can't start the engine can someone send me pictures of what setup should I use??? on the original control unit the engine works
