Vems Plug and play pin swap to RPM sensor
  • jade
    • Jan 2005
    • 1811
    Good Morning,
    Years ago I fitted the Vems and remember a pin swap on the rpm sensor on the bell housing….. There are 3 wires Pins 1 to 3 Can anyone remind me which 2 were swapped as I am changing to Maxx ECU so I would like to revert to standard
    Thank you
    RS 2 580HP
  • jade
    • Jan 2005
    • 1811
    The correct wiring
    RS 2 580HP
