VEMS motronic, need some help
    The joys of aftermarket ECUs once more - I just hate Megatune - it is so clunky to look at and the manual is poor also.
    Paul
    • a4kquattro
      • Feb 2005
      • 411
      scratch that, the final issue wasn't the software, it was testing on my desktop with a real serial port. I've never before had a problem with the PCMCIA serial card I use in my laptop (it would upload the firmware and verify fine using this device, however megatune had a problem with it!)
      oddly enough, megatune seems to like my usb to serial converter better than the pcmcia to serial adapter ? Whatever, it works, off to testing on the car and tuning!
      Thanks for all the help, I might be back with more questions
      Marc Swanson
      Proprietor, EFI Express
      95.5 //S6 Avant
      90' Coupe Quattro V8 4.2L twin turbo
      93' //S4
      83' UrQ
      97' F250 7.3 diesel
      • BRY
        • 3755
        Excellent news
        Keep us informed, I prefer clunky stuff that I can play with than sealed stuff that I can't.
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          I thought you'd be a Motronic guru by now Bry.
          SS
          • BRY
            • 3755
            #20
            Does Guru = Chip copier?
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              #21
              I believe some people think so.
              SS
              • BRY
                • 3755
                #22
                I'll order a load of blank chips then. :mischeif:
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  #23
                  Ask the dude for one of his DVDs, get some WG springs and you'll be well away.
                  SS
                  • spink
                    • 4382
                    here we go again,the other thread a few weeks back was hilarious(before it was edited)
                    • a4kquattro
                      • Feb 2005
                      • 411
                      aaaaand its running:
                      ignore the 'misfire' bit, I was testing some things..
                      Things that need to be sorted out:
                      1) Idle control: it was hunting badly using the config I saved from the files marcel posted. The car runs much better with it disabled at the moment.
                      2) connect the wideband sender. This ECU was configured to send the wideband signals over unused wiring in the engine bay, so a harness will need to be made.
                      Otherwise, I'm damned impressed. Too bad the wiring for the reference sender needs to be reversed otherwise it would be completely plug and play. I'd suggest that maybe VEMS could build a simple short jumper cable with a male and female 3 pin audi plug on either end so that the wiring can be reversed without having to re-pin the connector..
                      Great job to the VEMS team and everyone on here for their help, looking forward to playing some more!
                      Marc Swanson
                      95.5 //S6 Avant
                      93' //S4
                      83' UrQ
                      97' F250 7.3 diesel
                      • K7ERG
                        • 1711
                        Sounds good looking at getting this in the next few weeks.
                        Audi A6 AEL 5cyl Quattro breaking.
                        Audi A5 3.0tdi Quattro Stage 2
                        07947385043
                        • GazzaG60
                          • 4133
                          sorry i got my 1.1's and 1.0's mixed up.
                          good to hear its running.
                          wouldn't particularly say megatune was clunky. its actually a nice SW to use. feature sets change so often and depending on what you need depends on what you compile.
                          my idle is ok other than not catching too well every time. add 2.5% to the DC showed for the idle in the real time menu to set the idle.
                          must say i couldn't get marcels map to run. not sure if its my setup with the turbo and all but it didn't like it.
                            • 12431
                            Good you have got it up and working. ive seen some pics of the V8 Coupe before, wondered who was the owner of it
                              #29
                              If only it was that easy
                              • a4kquattro
                                • Feb 2005
                                • 411
                                ok, more questions to those who are in the know!
                                I have something strange going on with regards to boost control. Currently running firmware 1.1.23. When I go in to change values in the map vs. rpm table or any of the numbers in the secondary boost control screen the engine will miss under load, almost as if the fuel injectors are receiving a different duty cycle (boost does not change during this).
                                Also I ran into some triggering issues with the car around 6500 rpm. Should I be running a specific firmware over another to potentially solve this issue? I tried loading 1.0.73 and 1.1.29, neither of which allowed the car to run after loading the firmware (I didn't agressively investigate necessary config file changes so my bad there).
                                So what are you VEMS guys w/auditrigger setup running for firmware? How about boost control settings?
                                Thanks!
                                Marc Swanson
                                95.5 //S6 Avant
                                93' //S4
                                83' UrQ
                                97' F250 7.3 diesel
