I have an VEMS WB&EGT gauge and I want to add RPM signal for logging. I know witch cable I need to connect it, but i get very jumpy reading... it shows me RPM between 200 to 1300. Does anyone know what I need to configure to get correct reading? I read the vems WIKI page, but I don't understand very well what needs to be done
with VEMS in order to get a clean signal you need to change the polarity on the secondary VR sensor. not sure if it would but maybe the gauge uses the same logic and needs a reversed polarity.
