advise on ecu
  • s2martyn
    Banned
    • Apr 2008
    • 408
    advise on ecu
    advise on after market ecu needed..
    which is easyist to use.
    where to buy from
    crank sensor location(front pulley/flywheel?
    stock wiring or modded?
    the engine is aby with gt35
    will i need the maf/lambda sensor/cold start?
    would like to keep standard coils and no distributer?
    looking to buy in the next week
    prices???????
    • 12431
    Hi there are few on here that are using VEMS and Motec. However the Motronic should be tunable on a GT35 no problem
    • repo
      • Dec 2004
      • 893
      One choise is Tatech as well.
      PnP adapter is avalable for aby, so installation is very easy.
