I am considering an upgrade to VEMS some day (need to do install a larger IC and Sachs race clutch first), since it seems the OEM MAF (420HP max?) is restricting the potential of my setup at this moment and in the future. But since I have no experience in electronic engine management systems I feel hesitant to buy VEMS.
How safe is it for an ECU-noob like me to start such a VEMS project? Can I easily blow up my engine, or are there a few parameters to be set with Megatune to avoid heavily detonation, etc.?
Another issue I have is how to setup the initial VEMS config for my Turbo and Injectors. Are there base-maps available, or can I start the engine with a map that is made for smaller/bigger injectors? I understand there are some maps available for the AAN, but I guess these are optimized for k24 and standard injectors?
excellent summary
