Should i go VEMS
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    Should i go VEMS
    should i go vems??? I am seriously thinking about vems, i mean a new airflow meter to me here is almost the same value as one vems PNP. I have lots of programs for the 5coil car, but i need to do the conversion. And the vems is pnp, and i have more options later for my 2,5ltr stroker.
    What do you guys think???
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
  • spink
    • 4382
    I would do if i was you,especially as there is no one in your country who know's motronic.
    • gedu
      • Feb 2007
      • 295
      With all aftermarket ECUs you have the same problem. It works just as well its tuned. If you can tune it yourself, you are golden. If on the other hand you need someone to tune it for you, you should choose with care, as not everyone tunes everything
      All quattro products have been dermatologically tested, and are safe for daily use.
