do these have to be located at the lowest point of the water system?
Davis Craig Wtaer pump Queston
Tags: None
no im taking about the one im putting in the boot to help push the existing water pump, the unit can go below the bottom hose but part of the system will be lower than this where it runns down the underside of the car and i didnt want to mount the pump under the car if i could help it
cheers
will
I'm tempted to say, it should be ok to push the cooled water under the car, but if you can keep the heated water pipe from the engine a bit higher it might help?Martin Cutting
It's not better than sex, but it runs it a close second.Comment
yes will you need to put it lower than the radno im taking about the one im putting in the boot to help push the existing water pump, the unit can go below the bottom hose but part of the system will be lower than this where it runns down the underside of the car and i didnt want to mount the pump under the car if i could help it
cheers
will
